Old 04-12-2014   #1
chriskinzel
chriskinzel's Avatar
Default Fuel Pressure Gauge
I am looking to install a fuel pressure gauge on my 'A' pillar. I have not had any luck finding one that will connect to the fuel rail. I have found many test gauges, but none that is designed to go inside. If you have one will you let me know what brand and model it is. TIA
Chris
91 ZR-1 Red on Red #922
chriskinzel is offline   Reply With Quote
Old 04-12-2014   #2
Franke
Default Re: Fuel Pressure Gauge
Chris
Chris, try Google for remote fuel pressure gauges. You will find them in digital and analog readout with a electronic sensor. You may need to adapt 1/8 NPT to Schrader valve fitting depending on the manufacturer.
