04-08-2014 | #1 |
Where does your clutch engage on the pedal? High or low? ---
I have noticed my clutch lets out really high up , almost where the pedal is fully disengaged (maybe an inch from the top).
Is this typical for our systems? The clutch on my Viper engages really low , about an inch off the floor (opposite of the ZR-1). I wasn't sure if this may be a clue that I am about ready for a new clutch? I don't notice it slipping at all , so it may be normal ... but I was just curious enough to ask you guys. The car has 44k miles on it , and got the LPE topend package installed at 23k miles ... so not sure if its the original still or not. I tend to get the loud transmission sound after everything is warmed up too. I think my flywheel weights are flopping around if its even the dual mass anymore. If it is time for a clutch and flywheel replacement, whats everyones favorite aftermarket combination to look into? Thanks! ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
04-08-2014 | #2 |
Re: Where does your clutch engage on the pedal? High or low? ---
Mines always high
04-08-2014 | #3 |
OK, that's great news, thanks Goldcylon! ---
04-08-2014 | #4 |
very high but Marc Haibeck told me that means I need to replace the clutch
04-08-2014 | #5 |
Ive never ran a clutch out until it failed before.
Whats the worst that can happen , it locks you out of shifting? What kind of damage can happen? Isnt there a way to test if you are slipping or not by putting it in 4th gear at a low rpm, then giving it a good amount of throttle (then watch if the RPMs rise too quickly)? ---
04-08-2014 | #6 |
Mine is very high also and the clutch in it does not have much feel to it, it's either engaged or not...Makes stop and go driving a Royal pain in the Butt.
Previous Owner had an Aluminum flywheel and Heavy duty clutch of unknown origin installed, I'm going to try changing it out for a more Street Friendly version.
91 ZR-1 Arctic White/Gray 01 C-5 Magnetic Red/Black 85 FJ 1100 (Big Bore kit, Hooligan Bike) 05 FJR 1300 Yamaha (Long Distance, Sport Touring) And a whole whack of RC Planes |
04-08-2014 | #7 |
My 91 is just past mid way with new clutch & PP Marc just installed it. The 93 is about the same with 26k miles.
04-08-2014 | #8 |
Mine is midway between all the way up and to the floor.
04-08-2014 | #9 |
Transmission syncro's.
04-08-2014 | #10 |
That's if you try to force it into gear though, right? ---
