Old 10-04-2006   #1
2nd94Z
2nd94Z's Avatar
Default No reverse lights
No Reverse lights, fuse is good,
switch in/on trans, and where ?
2nd94Z is offline   Reply With Quote
Old 10-04-2006   #2
Jeffvette
Default Re: No reverse lights
Switch is on the trans driver side, upper half of the motor. Check continuity at the switch.
Also contact www.zfdoc.com
Old 10-04-2006   #3
guinnessdood
guinnessdood's Avatar
Jeff..thanks...mine are out too...I'll hafta get them fixed. Should be an easy fix.
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 10-04-2006   #4
1990 quasar blue
Uly, others have said it's a PITA which is why I've been putting mine off. I have a picture of a tool that someone made to make the job easier. If your interested, I'll send it to you in an email. I don't have a way to post pix.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 10-04-2006   #5
Aurora40
Aurora40's Avatar
I borrowed a tool from Bill B that made it much, much easier. I think he charged like $5 for rental plus shipping.
Bob Saveland
Former owner of #2517
Old 10-05-2006   #6
2nd94Z
2nd94Z's Avatar
PITA ?
Tool for ?
please explain ?
Old 10-05-2006   #7
The switch can be replaced using tools available at Sears. Here is the information I posted in 2004.
The back-up light switch can be changed using common tools bought at sears. Buy a 22 mm 12 point deep socket, cut it off so it is just long enough to reach the bottom of the hex on the switch. Buy a 3 piece socket cap set from sears (these are adapters that plug into the socket that let you turn the socket with a wrench). Put the socket cap into the socket, put the socket on the switch after removing the electrical connector from the switch, and break the switch loose with a wrench. Remove the socket from the switch once the switch is loose enough that you can turn it by hand. There is not sufficient room to leave the socket on the switch and screw the switch all the way out. Before removing the switch you will need to take the slave cylinder loose from the bell housing and move it to the side to give you more room to work. There is also a small clamp on the line leading to the slave cylinder to remove to allow the slave cylinder to move easier. The piston in the slave cylinder is spring loaded and will extend when you remove the slave and you will have to re-compress the spring when you re-install the slave.
Tom is offline   Reply With Quote
Old 10-07-2006   #8
Corvette95
Corvette95's Avatar
did you ever get it fixed?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 10-12-2006   #9
2nd94Z
2nd94Z's Avatar
Not yet, looking for a lift.
Old 10-12-2006   #10
I just use a floor jack and jackstands and/or rhino ramps.
