Old 01-04-2014   #1
bradley
Default where are the drain plugs...
on the block for the coolant ???? I would like to drain everything a couple of times since it is time to change the coolant .
bradley is offline   Reply With Quote
Old 01-04-2014   #2
Default Re: where are the drain plugs...
Bottom right side corner,its recessed a bit so you will need to feel around for it.
