Old 08-28-2013   #1
Kevin
Kevin's Avatar
Default does the zr-1 share a clutch master cylender cap with the base car?
tittle pretty much says it all. wondering if the zr-1 master and the base car clutch master share the same cap
Old 08-28-2013   #2
Default Re: does the zr-1 share a clutch master cylender cap with the base car?
From my understanding up until MY 91. The 89-91 MC are the same. Booster whole different animal
Old 08-28-2013   #3
Kevin
Kevin's Avatar
Default Re: does the zr-1 share a clutch master cylender cap with the bast car?
good to know, thanks mate
Old 08-28-2013   #4
Kevin,
You mean clutch master or brake master???? All the clutch master cylinders from the aftermarket use the same cap, and all the masters from original GM parts are the same cap....but I don't think the OE and after market caps are the same.
Old 08-28-2013   #5
Yeah that threw me off Tom as well. The Brake master caps are the same from 89-91 cap(s) wise. The clutch master cylinder is the same from 89-96 I believe for all ZF transmissions
