Old 08-21-2006   #1
Tim
Default Service engine soon light, oh my god
Hello fellow members, I need your help. Last weekend I took my 90Z (basically stock DRM chip and 4:10s) to an 1/8 mile drag strip. Drove the car up there, approximately 100 miles, and topped off the fuel tank with 6 gallons 108 octane gas and made five runs. The car ran fine, just could not get traction. Anyway, after my runs watched for a while, hopped back in my Z and cruised home. Everything seemed normal and the car ran fine. We made two stops on the way home and every time we proceeded again the car still ran just fine. Got back to Bismarck and stopped to visit with some friends for about four hours and then decided to take the car home. We started the car and it idled rough with black smoke out the exhaust. As soon as I touched the gas, the idle picked up, exhaust cleared up, and service engine soon light came on. Drove my baby home about eight blocks and it ran okay but the service engine soon light stayed on.
The following morning I went out and started it several times with the same results. Started it without touching the gas and it idled very rough with black exhaust smoke, tapped the gas and it goes into high idle and the exhaust clears up and then the service engine soon light comes on again.
Does anybody have any idea of what is going on? I hope I didn't hurt my baby, baby, baby.
Can anybody also provide a link to where the instructions are as to specifically where and how to check codes and what they would mean?
THanks, Tim
Tim is offline   Reply With Quote
Old 08-21-2006   #2
tccrab
tccrab's Avatar
Default Re: Service engine soon light, oh my god
Tim:
Sounds EXACTLY like you've had a small backfire on starting it and have blown off the Map Sensor hose.
Behind the plenum on the drivers side is the PCV connector, check the small piping just to it's left, there are two connectors, one upper and one lower. It's always the lower one that seems to blow off. Just push the connector back on and you'll be good to go.
Been there, done that.
Good luck!
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 08-21-2006   #3
Jeffvette
Tom has got it. Hold the key over until the car completely catches. You won't grind the starter.
