Old 07-11-2013   #1
chriskinzel
chriskinzel's Avatar
Default Falling on it's face
Took the old gal for a ride tonight. Everything started ok running good. Decided to make a run up the canyon and she started not wanting to run past 3k. It did this regardless of what position the power key was in. I changed all injectors 750 miles ago, and both fuel pumps and filter last summer. It seems like a fuel issue, and I have not pulled out my fuel Preasure gauge yet. It seems fine if you keep it under 3k, or less than 1/4 throttle, but what fun is that! Any ideas from the great brotherhood?
Thanks
Chris
91 ZR-1 Red on Red #922
chriskinzel is offline   Reply With Quote
Old 07-11-2013   #2
SteelBlueZR1
Default Re: Falling on it's face
Sorry to hear your troubles. I would pull codes and see if you have any codes. You may have a secondary port low vacuum code, which I think is a code 61. My car behaved the same way when the secondary port solenoid went bad. Would stumble like hell above 3k and make no power. However, come to think of it... the car ran ok with power key off.
Also, definately check the MAP hose and replace it if it is not snug fit, and/or is not the oem design with a hard plastic tube. Jerry's Gaskets has the NOS part.
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
Old 07-11-2013   #3
tf95ZR1
tf95ZR1's Avatar
My car ran great up to 4K rpm then "fell on its face"
Vacuum reserve was used up so secondaries closed.
New vacuum pump: problem cured!
Just sayin'
This happened years ago at the Nellis AFB Mile Run,
Gathering West (lets do it again!)
Marc Haibeck happened to be there and diagnosed the
problem literally in 30 seconds. Also, Rick Jesperson
happened to have a spare pump with him!
Picture Marc sitting on my tire on the tarmac changing out my pump.
Priceless!
Old 07-11-2013   #4
Pete
Pete's Avatar
Yeap, sounds like secondaries are shutting down.
Check vacuum pump if it works and you have a 1990 -1992 get a long piece of vacuum hose and connect one end to vacuum pump the other to the MAP sensor under your ECM if all good look for vacuum leak.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-11-2013   #5
My pump worked fine till the day I decided to remove the secondaries as part of my FBI porting. If it turns out to be a vacuum pump, I'll give you mine to a good home.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-11-2013   #6
chriskinzel
Thanks for all the advice. Sound vacuum related. I will check the pump for operation and leaks. I will also pull codes. Maybe it's time to remove secondary's. If I do yank them, do I need to get a chip from Marc H.? Whatever it is it sounds like some good under hood time with the tools! I will let you know what the outcome is.
Thanks
Chris
Old 07-12-2013   #7
chriskinzel
Vacuum pump runs fine. After I tuen the key on it runs for about 2 seconds, the shuts off. Pulled codes and I have a 43. I seems to run fine until it gets hot, then it seens to have problems. Ideas>
