Old 06-02-2013   #1
DarkAngel
DarkAngel's Avatar
Default Unknown strange engine noise
Hello,
Ive made videos this week-end about a strange engine noise that i cannot identify
It appears when the engine is running and also when it stop, it makes a metalic noise like "rattle"
on the third video, we can hear it a little but usually it makes much more noise
The belt tensioner does not seem to move excessively and ive checked that the alternator and climate pump is tight correctly
If someone has an idea from where it can come from ...
Thanks for your help
1) http://youtu.be/OpJT7LIqf9M
2) http://youtu.be/Mc3TUkZx-zA
3) http://youtu.be/QFJsKHduLTo
DarkAngel is offline   Reply With Quote
Old 06-03-2013   #2
geezer
Default Re: Unknow strange engine noise
Sounds like belt tensioner/ bearing. Easily available on the internet.
IMHO
geezer is offline   Reply With Quote
Old 06-03-2013   #3
scottfab
scottfab's Avatar
1. Remove the belt and inspect it for a bad spot.
2. Belt ok? then spin each, water pump, A/C, alternator, idler pulley and tensioner pulley as well as the PS pump. Listen and feel for any grinding.
Scott
Old 06-03-2013   #4
DarkAngel
DarkAngel's Avatar
thanks for your answers, i will try to check this
regarding the belt tensioner, what is the difference between this one :
http://www.whiteracingproducts.com/i...products_id=91
and the one from ecklers
http://www.ecklerscorvette.com/corve...1988-1991.html
there is a huge difference of price between them
Old 06-03-2013   #5
Just in case you want to try something different
Experimental Bling
Old 06-03-2013   #6
geezer
Functionally no difference. If you isolate the problem to the tensioner pulley ( as per Scott fab suggestions) try Jerry's Gaskets for the best price on a OEM pulley.
Old 06-03-2013   #7
Blue Flame Restorations
Dual mass??? Where is the noise coming from? Front or rear of engine?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-03-2013   #8
mike100
The cheap one does not fit the LT5. Marc Haibeck rebuilds the tensioner part if it doesn't turn out to just be the pulley bearing. i think it could also be a bad alternator bearing- removing the belt and hand spinng some of those accessories might tell you.
Old 06-04-2013   #9
DarkAngel
DarkAngel's Avatar
Originally Posted by Blue Flame Restorations View Post
Dual mass??? Where is the nokise coming from? Front or rear of engine?
it seems it comes from the front of the engine
Old 06-04-2013   #10
rkreigh
sure sounds like the tensioner, and that pulley has a strange wobble to it too
probably the bearing is shot.
start the engine briefly without the belt
wiggle each pulley other thing that can happen is (rare) the chain guide can fail and make a racket - hope it's not that!!
95 390 LPE ZR1 (505 rwhp)
