Old 05-30-2013   #1
Schrade
Default Need thread pitch / spec / dimensions...
The speed shop called today; they need "thread pitch" for the Air Inlet fitting (to the exhaust manifold???).
I'm not 100% sure of the hardware configuration, since they've had the car for most of the year that I owned it - I know only what he described. I told him I'd go through the FSM to see what I could find.
Anyone already familiar with what they're describing, that they need?
Old 05-30-2013   #2
Blue Flame Restorations
Default Re: Need thread pitch / spec / dimensions...
Contact Jerry's Gaskets. Jerry will know.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-30-2013   #3
Schrade
Will do Brett; thanks there...
Old 05-30-2013   #4
Jagdpanzer
Jagdpanzer's Avatar
Please point it out:
http://jerrysgaskets.com/store2/root..._image&pID=378
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-31-2013   #5
Schrade
I'm presuming here, jagdpanzer, that he needs the thread pitch of the encircled fittings:
Why, I don't know, but I'm off to get up there in the AM here.
Where's Jerry here? Know the thread dimensions???
Old 05-31-2013   #6
mike100
I think it is 3/4" and the thread pitch is 14NC. I just repaired an air tube fitting and i got a bushing with the same external thread.
Interesting to note that many of the small block applications one-way air injection check valves are one size smaller.
The 63-504 fit on my repair: http://www.downwindmarine.com/Pipe-R...-90891187.html (note dimensions are for inside diameter and threads- the outside is 3/4's)
Old 05-31-2013   #7
Schrade
Thanks there Sir..................................
Old 05-31-2013   #8
WVZR-1
In that image the threads are 1/2" - NPT which when measured externally is a dimension something near .830 or so. !/2" NPT is 14 TPI as is 3/4 NPT but 3/4NPT is a dimension greater than 1" when measured externally. NPT is based on the internal diameter of the pipe. The bushings that "mike100" references to are NPT also and the reference to a 14NC is not correct, it's 14 but it's NPT. The image is that of a later manifold but I believe the AIR check valves are the same all years.
1/2" NPT 14 TPI
Old 05-31-2013   #9
Jagdpanzer
Jagdpanzer's Avatar
I have to agree with Dave, 1/2" npt tapered pipe thread
When I get home this evening I will dig out one of my old exhaust manifolds and confirm.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-31-2013   #10
mike100
yeah, I guess the 1/2" refers to the ID of the bushing...I just recall finding some parts in the plumbing section of a good hardware store here. I was going to hack off some fitting from the junkyard, but the LT5 air injection is double tubed and uses much larger check valves (thread-wise) than most of the small block cars.
At any rate, the link above for the part I mentioned is the correct thread.
