Old 05-20-2013   #1
laboss3
Default Clutch slave
Hi does anyone know who sells a steel clutch slave cylinder replacement. All I can find is the cast model I would rather have the steel one and not the cast one. Or possibly a rebuild kit would do also. It's for a 1990 zr1.
Any help would be appreciated
Bob
laboss3 is offline   Reply With Quote
Old 05-20-2013   #2
Default Re: Clutch slave
http://powertorquesystems.com/
Old 05-20-2013   #3
scottfab
scottfab's Avatar
http://www.rockauto.com/catalog/more...272&cc=1041275
and also
http://www.rockauto.com/catalog/more...431&cc=1041275
Scott
Old 05-20-2013   #4
laboss3
Thanks guys I have a call into zf doc if he can't help I will try Powertorque Systems. I tried rock auto but they didn't know what they had cast or steel didn't get a warm feeling. Too bad I have used them in the past but the tech couldn't take a look to see what he had in stock.
Bob
Old 05-20-2013   #5
efnfast
2nd'd
Old 05-21-2013   #6
scottfab
scottfab's Avatar
Bob
Rockauto has both cast and steel. They list about 6 or 8 that fit the 90.
The links I sent are the two steel ones going by the pics. The others were obviously cast going by the pics.
When I replaced mine I used a cast part.
Scott
Old 05-21-2013   #7
vettn71
Jim at PowerTorque rebuilt my master and slave. Only way to go, as many of the new units may be misassembled. I had the cast units in my Z while I waited to get the originals rebuilt and they just don't feel the same. Call Jim. He's a great guy to work with
vettn71 is offline   Reply With Quote
Old 05-22-2013   #8
laboss3
Made contact with Jim at power torque systems and am buying one from him. Thanks for all the info and help.
Bob
Old 05-22-2013   #9
Schrade
If you don't close there, I have all the hardware from my '90 ZF after doin' the auto conversion; 'Doug' has 1st dibbs on the tranny - if you're interested, I can get up with him to see what other parts he might want... (hardware has 32k on it).............
Old 05-28-2013   #10
POWERBRAKEBOB
I'm pulling mine out to fix the leak. I used to be a Girling Distributor, and had new ones years ago. When I take it apart, I will see if I have the seal kit needed. I have built tens of thousands of power brake units. Many seals will interchange on cylinders. IF I figure out the seal kit, will there be anyone interested in ordering? you can see my videos at youtube.com/powerbrakeservice
POWERBRAKEBOB is offline   Reply With Quote
