Old 05-09-2013   #1
tf95ZR1
tf95ZR1's Avatar
Default FYI & Help: Cadillac CTS Spare Won't Work
I decided to start a new thread instead of hijacking a past thread.
The problem: a spare tire if you run BIG brakes. Up front I have
C6 ZO6 calipers with Fiske 18" rims. Someone smarter than me
realized that if we get a flat tire, the 17" spare won't fit. Fix-a-Flat
won't work if the hole is in the sidewall.
It was said that a 2008-up Cadillac CTS 18 X 4 compact (donut)
spare tire will fit and work. Locating one was difficult since this spare
was only a CTS option. The CTS came with a repair kit including
a mini compressor.
I finally found a CTS spare in Texas. i tried it tonight and not even
close to clearing the front face of the caliper. Diameter is fine. I
would not only need a 1/2" spacer, but have to get longer wheel studs
all around. Anybody have any ideas? TIA!
PS: I asked for Fiske's help years ago and they were of no help.
Maybe now with new ownership I'll try again.
Old 05-09-2013   #2
Pete
Pete's Avatar
Default Re: FYI & Help: Cadillac CTS Spare Won't Work
Hi Ted
What would be the problem going with longer studs and a spacer only for emergency.
1/2" doesn't really sound too bad.
I would say try it, buy one stud and some washers (1/2") for trial fit.
Just a thought.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-09-2013   #3
tf95ZR1
tf95ZR1's Avatar
I hear you, Pete! It just sounds cleaner if I could find the correct
wheel. It must be possible as I have wheels that fit now.
And, I'd have to replace all 20 studs, plus would my current
lug nuts fit with longer studs on my wheels?
Old 05-09-2013   #4
The lugs will work,open lugs but the lug covers might not go on the lug nut with the stud coming out the front side.You might be able to -dial in- a wheel stud and get the cover on the nut.Dial in meaning trim the stud until it will work with the cover and still be long enough to use a spacer.
Old 05-09-2013   #5
WVZR-1
Ted,
Several months ago I posted up I believe a solution to the spare and within minutes a "moderator" had messed with the snapshots, that PMO and I deleted the entire entry.
I have your solution, I've emailed you. You'll need no wheel studs.
-Dave
Old 05-09-2013   #6
secondchance
Ted,
-Dave
Dave,
I am looking at same option since I'll be going to big brakes also. Can you share your solution?
Hope all is well!
Old 05-09-2013   #7
Same issue here. I have been communicating w Randall Maddox at www.performancespare.com since they do spares for Camaro and CTS-V. These cost ~ $300. There is an alternative that can be found on the C6 forum and built for the Z06 but the price is over $900. One solution for the longer wheel studs is to use an adapter rather than spacer to push the wheel out. I had the opportunity to buy a GTO spare but it wouldn't work without a 3.5" spacer which I thought ridiculous. Could use a stock C6 18" wheel and just carry in hatch area
http://www.vettespare.com/ basically uses a C6 wheel narrowed for an 18" spare. However, the price is a lot more expensive than a tow and new tire IMO.
Also, looked at the ContiComfort kit to flats that are not sidewall damage.
I just may look for C6 wheel and tire just to have something for long trips. Maybe we could buy a set and split it up .
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-09-2013   #8
If somebody didnt mind spending some money,why not get in touch with one of the wheel manufactures and have a wheel made,sure wouldnt cost anywhere close to $900.
Old 05-09-2013   #9
what about a wheel adapter and 5 extra lugs?
the adapter would bolt to the existing 5 wheel studs, then the wheel would bolt to 5 studs on the adapter
like this:
Not optimal but neither is a flat
Old 05-09-2013   #10
tf95ZR1
tf95ZR1's Avatar
like this:
Yes, this style adaptor would work, I just thought the compact spare would
be a "drop in" kinda like a Fluidyne radiator (wink, wink, causin' some fun).
PS: I like "Not optimal but neither is a flat"
