Old 04-13-2013   #1
Corbusa
Default Transmission fill / drain plug question
I went to drain my trans fluid today, and noticed someone had used channel locks or something on the fill plug, . it also looks like they might have tried the wrong tool on the inside of the plug. So my questions are what is the correct size of the fill and drain tools? and are the plugs available to buy? I'm sure there has got to be a few different transmissions that use the same plugs. ( ps i didnt remove the plugs , I am waiting to try and use the correct allen socket. thanks
Old 04-13-2013   #2
Default Re: Transmission fill / drain plug question
17 mm Allen Wrench
Use a small hammer and tap allen wrench end into the center of the drain plug.
If that does not work....you will have to use channel locks or small pipe wrench on outside of plug.
Actually.......I would insert the 17 mm Allen by tapping and then place channel locks on outside using both wrenches.
The Trans Drain Plug is the same size and is usually scuffed from road rash.
You can use a larger box wrench over the end of the 17mm allen end as leverage along with the channel locks on outside of plug.
The transmission fill and drain Plug threads are M24 x 1.5 and zfdoc should have them
When you install the plugs use a bit of Permatex Form A Gasket Sealant (or similar) and do not tighten plugs too much.
See Note D
LT5/ZR-1 Fluids
REMOVE THE FILL PLUG FIRST
Old 04-13-2013   #3
Corbusa
Thanks Bro
Old 04-13-2013   #4
WVZR-1
The plugs are 24 X 1.5 but I believe they're "tapered pipe" similar to our tapered pipe thread. You could do them locally but you give up the 17mm hex of the standaard ZF plug. If you're not concerned with the originality they should be quite readily available. An off the shelf 906 DIN I believe is a 12mm hex.
If your concern was just the "fill" plug you could actually do that with a "conventional hex" A conventional hex is a 909 DIN.
Old 04-28-2013   #5
Corbusa
Guys will this work? http://www.ebay.com/itm/Auveco-18027...c4f28c&vxp=mtr
Old 04-28-2013   #6
Corbusa
Also the drain plug is smaller , does anyone know what size allen? thank you ..
Old 04-28-2013   #7
WVZR-1
NO ! That plug is NOT a "tapered pipe thread". That is an oil/transmission style drain plaug that requires a gasket. Besides the BOX states 25mm x 1.5. The HEX is 24mm for the wrench.
The drain & fill are the same! If yours are different then one or the other has been replaced with something other than OE. Cliff mentioned the 17mm hex and I mentioned it again.
Old 04-28-2013   #8
Corbusa
Ok Thanks I guess my trans plugs have been changed . My drain is smaller . I did buy a 17 mm allen and it kind of fits the fill plug ( but someone messed it up ) the drain looks like maybe a 14-15 mm
Thanks WV
PS I did call ZRDOC last week but couldnt get a hold of anyone.
Old 04-28-2013   #9
WVZR-1
Thanks WV
You don't need him for the plugs. I'm sure they're off the shelf BMW, VW or MB.
I'll try to slip you a part number!
Here's a Magnetic with the correct 17mm hex BUT "NOT IN STOCK"!
https://www.pegasusautoracing.com/pr...asp?RecID=4060
Old 04-28-2013   #10
Corbusa
M24X1.5, METRIC TAPER : EARLIER MANUAL TRANSMISSIONS
M24X1.5 TAPERED
A SPECIAL MADE DIMPLEĀ® SUPER MAGNETIC DRAIN PLUG FOR THE BMW EARLIER MANUAL TRANSMISSIONS, now in true Yellow Chromate protective plating.
THIS PLUG IS THE LARGE M24X1.5 TAPERED METRIC THREAD.
IT FEATURES THE IDEAL FACTORY 17MM EXTERNAL HEX DRIVE. FITTED WITH A LARGE, DEEP SET, LOW PROFILE 1/2" DIAMETER MAGNET FOR OPTIMUM PERFORMANCE.
OUR INTENT IS TO KEEP YOUR TRANSMISSION CLEAN OF ALL HARMFUL METAL PARTICLES WHICH THEN ALLOWS SYNCHRONIZER'S AND BEARINGS TO ROTATE FREELY IN CLEAN OIL, FOR LONG LASTING DEPENDABILITY.
$34.95
YOU WILL BE GLAD TO KNOW THIS OIL PLUG FITS THE FOLLOWING BMW CHASSIS FITMENTS:
1 SERIES = E87
3 SERIES = E21, E30, E36, E46
5 SERIES = E12, E28, E34, E39
6 SERIES = E24
7 SERIES = E23, E32, E38
8 SERIES = E31
X5 = E53
Z3 = E36
Z4 = E85
Z8 =E52
