07-04-2006 | #1 |
ALDL connector?
I guess it's supposed to be beside the column to the right on the lower dash. Mine isn't there. Must be stuffed up under the lower dash panel. Anyone got a pic of what it looks like and where it should be? That way I can return mine to it's proper location once I trouble shoot my issues. Thanks!
07-05-2006 | #2 |
Re: ALDL connector?
The location you describe is correct. You will most likely have to pull the knee bolster to find it. It should mount to the bolster with a screw on one side of the ALDL plug. I’m sure you will see the spot once you get the bolster down.
