01-22-2013 | #1 |
What Is It?
I lost my mind...where do these T-40 and two clips go under the hood or on the LT5?
No...This is not the first time I had brain freeze Thanks, Cliff |
01-22-2013 | #2 |
Re: What Is It?
The T40s are for the rear hold downs for the roof panel.
The others are from a 60 series John Deer combine http://talk.newagtalk.com/forums/thr...23&mid=1388269
01-23-2013 | #3 |
Re: What Is It?
Doesn't the silver clip hold the tranmission cable to the upper left side of the transmission? The small hole holds the plastic holding tab for the cable.
'93 #166 Black Rose “Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” Heraclitus |
01-23-2013 | #4 |
Re: What Is It?
The ones on the left are self-sealing stembolts, the ones on the right are phase coil induction mounts...
Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
01-23-2013 | #5 |
Re: What Is It?
'93 #166 Black Rose “Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” Heraclitus Last edited by MikeGolf; 01-23-2013 at 01:41 AM. |
01-23-2013 | #6 |
Re: What Is It?
The screws look like from the trg top.
The silver bracket is to hold down the vent tube for the transmission and the harness for reverse switch,1-4 skip plug,and speedo. The other looks like it holds a harness wire loom that goes over and around the rear end tunnel just over the C-beam and rear end. Pete
01-23-2013 | #7 | |
Re: What Is It?
Quark would be so proud
01-24-2013 | #8 |
Re: What Is It?
Just remembered the loom clip could also be for the harness that runs along side the driver side fender well that one of the fender well screws goes thru it.
Pete
