Old 06-07-2006   #1
8upZR1
8upZR1's Avatar
Default Trouble with trouble codes
Can anyone tell me if I should be getting a trouble code if I unplug a sensor, say cam or crank, and then try to start the car? Does the motor need to run to register a trouble code? If I get no trouble codes does it mean my computer is shot? Is the ECU also responsible for trouble codes or is there a seperate computer for diagnostics? I would greatly appreciate anybody's input, thankyou.
IT IS THE FATE OF THE INNOCENT TO MEET WITH DEATH!!!
8upZR1 is offline   Reply With Quote
Old 06-07-2006   #2
Jeffvette
Default Re: Trouble with trouble codes
You have two seletions for codes. ECM and CCM. Depending upon the year of the car will make a dfference as well as to how much they integrate with one another.
Codes will be set with the car running.
Unplugging a crank sensor will not set a code from my memory. Makes it tough to trouble shoot.
What is the issue you are having?
Old 06-07-2006   #3
tccrab
tccrab's Avatar
Jeff:
He's got major troubles, here's a link to his other posts...
http://www.zr1netregistry.com/forum/...ead.php?t=1832
TomC
'90 ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 06-08-2006   #4
Tyler Townsley
See my reply on your other post. I am going to Bloomington next Tues, if you can meet me at an I 75 exit I can lend the ISS tester to you for a few days as I will be comming back through on Monday of the next week.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 06-08-2006   #5
8upZR1
8upZR1's Avatar
Trouble codes set only when running huh? That does make this infinitely more difficult.
I would greatly appreciate borrowing your ISS machine. If I haven't found a solution by the end of Sunday I would love to meet up with you. Thankyou for all your help.
