Old 08-06-2012   #1
Daniel_Mc
Daniel_Mc's Avatar
Default Secondary Vaccum Pump
Hey Guys is this what I need as a replacement? The pump took a dump on me...
The Bay link
It looks like the correct item but it got me thinking where it stated
"This pump is used in Kodiak/Topkick trucks for the AC & Heater Controls. On a 91-95 Corvette ZR1 it can be used as a direct replacement for the secondary pump. Can also be used on 1990 ZR-1 with this adapter (GM Part#12102747)"
Thanks,
Daniel
[COLOR=black]Daniel McGuffee [/COLOR]
[B]1989[/B] Red Coupe #10166
[COLOR=black][B]1989 [/B]Black[/COLOR][COLOR=black] Coupe #23990[/COLOR]
[COLOR=black][B]1991[/B] ZR-1 White #1639[/COLOR]
[COLOR=red]FRANK APPROVED ZR-1[/COLOR]
[B][COLOR=red][COLOR=black]1996[/COLOR] G[/COLOR][COLOR=blue]rand[/COLOR] [COLOR=red]S[/COLOR][COLOR=blue]port[/COLOR][/B] [COLOR=black]Coupe #564[/COLOR]
"It's not about the car, it's about the people..." DJ
Don't forget to support your [URL="http://corvettemuseum.com/"]National Corvette Museum[/URL]!!!
Daniel_Mc is offline   Reply With Quote
Old 08-06-2012   #2
Default Re: Secondary Vaccum Pump
Yes it is.
Old 08-06-2012   #3
tpr60
Yes they work and fit. You can also use Ford diesel vaccume pump, you will have to make up a jumper harness. I use the Ford pump it is available on e-bay for about $$55.
tpr60 is offline   Reply With Quote
Old 08-06-2012   #4
Daniel_Mc
Daniel_Mc's Avatar
I need to get ta picture but somewhere down the line the pump was wired into the fog lights. Any thought as to why someone would do this?
Daniel
Old 08-06-2012   #5
VetteMed
Does the ECM provide +12V, or a switched ground, to turn on the pump? GM often uses switched ground to actuate devices controlled by the ECM or CCM, so perhaps the +12V source is shared by the fogs and the pump?
Old 08-06-2012   #6
Daniel_Mc
Daniel_Mc's Avatar
I have no idea I haven't gotten into it very far yet. The wire job does not look factory at all.
Daniel
Old 08-06-2012   #7
Daniel
Dan,
If you're interested, I have mine (92) that is not in use and would be willing to sell if you are interested.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
