Old 06-05-2012   #1
Default Before and After Dyno
Dyno results from beginning of tuning to last session.
~+20rwhp/+10rwtq
Changes include:
SW Xpipe
DynoMax Ultraflow w Z06 flappers
Re-ported IH's
I think if I went back again I would lean out fuel just a bit morew some more timing at lower rpms. However, one thing that is disappointing is that it seems from the graph that the dyno operator was lifting at about 6800rpm rather than going thru 7K. Looking at the slope of the curve (blue), it looks like the trajectory may have gone a bit higher. Note how the before ad after lines are increasingly diverging.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-05-2012   #2
Default Re: Before and After Dyno
20 + 10 that's nice work 1
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 06-05-2012   #3
scottfab
scottfab's Avatar
good AB test with actual data.
Data always beats "feel" for accuracy.
Scott
Old 06-05-2012   #4
Tony Davila
Tony Davila's Avatar
I think if I went back again I would lean out fuel just a bit more, some more timing at lower rpms. However, one thing that is disappointing is that it seems from the graph that the dyno operator was lifting at about 6800rpm rather than going thru 7K. Looking at the slope of the curve (blue), it looks like the trajectory may have gone a bit higher. Note how the before ad after lines are increasingly diverging.
Most of the Tachs are off by 1000 RPM up high. My tach is off by 1000 past 7000 and 200 off at idle.
Tony Davila is offline   Reply With Quote
Old 06-05-2012   #5
rhipsher
rhipsher's Avatar
Still Dom at 434rwhp I wouldn't be complaining at all. And I take it that's without head work.
Old 06-05-2012   #6
RHanselman
RHanselman's Avatar
Very nice! now it's time for some boost!
RHanselman is offline   Reply With Quote
Old 06-06-2012   #7
no, he has a set of GVD Ported heads on it
Old 06-06-2012   #8
Tony,
This was the rpm output from the dyno connected to ignition. You can see it with the lifting at about 6800rpm.
rhipsher,
Just to clarify, the motor has Pete's regrind for the intake cams, GVD ported heads and DIY top end porting. A few months ago I listed measurements I made on the GVD porting. In comparison to what Pete and Marc do for porting, I would characterize it as "conservative"(not in the political sense ). Starts out at 36.5mm on deck and then necks down to 34 or so at the bowl.
I think all of the examples we've seen in the last year or so suggests to me that an aggressive head porting (36mm+) is probably the best bang for the HP buck.
It's my opinion that my current heads don't take full advantage of the cams. Having said all that, the 434rwhp feels pretty damn good.
BTW due to time constraints, these hp #'s were done with coolant temps at
193F.
Old 06-06-2012   #9
rhipsher
rhipsher's Avatar
Tony,
rhipsher,
193F.
I gotcha! I'll bet the hp does feel pretty good. You outta be running in the high 11's to very low 12's if at all in the 12's.
Old 06-06-2012   #10
Gotta get the power to the ground. Need DRs altho I will say the Nitto Invos on the car are a sticky street tire.
