Old 04-03-2012   #1
Mystic ZR-1
Mystic ZR-1's Avatar
Default Oil Cooler Line Leaks
It finally happened (on the 1st ride of the season!), the swaged fitting on upper hose leaks where it connects to the tubing/elbow going into the cooler.
Any suggestions? Where can you get the braided stainless hoses with the preinstalled fittings etc?
Thanks,
Doug
Old 04-03-2012   #2
Default Re: Oil Cooler Line Leaks
Thanks,
Doug
I think Kurt (Limey) had some still for sale I dont think the Haibeck ones are braided
Old 04-03-2012   #3
VetteMed
And there's also the option of having a local hydraulic shop make up a set for you, if all else fails.
Old 04-04-2012   #4
Blue Flame Restorations
Jerry's Gaskets sells them. I just bought a unit.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-04-2012   #5
wasn't corvette central or some place selling them too?
Old 04-04-2012   #6
Unless I am mistaken none of those are braided as requested by the OP ?
Old 04-04-2012   #7
mike100
Just a little clarification here- you'll need to have a fitting or nut welded onto the oem tubing because the line crimping machine won't fit around the double line setup. With fittings welded onto the original flange, a shop can make two separate hoses easily enough that you screw on later.
Old 04-04-2012   #8
limey
http://www.whiteracingproducts.com/i...oducts_id=1001
[SIZE=3][B][COLOR=Red]Worlds largest ZR-1 LT5 Parts Store[/COLOR][/B][/SIZE]
[URL="http://whiteracingproducts.com/"]http://whiteracingproducts.com[/URL]
New & Used Parts, as well as free Locator services.
[EMAIL="sales@whiteracingproducts.com"]sales@whiteracingproducts.com[/EMAIL]
(813) 264-6368
limey is offline   Reply With Quote
Old 04-19-2012   #9
Norsky4360
I also just ordered a hose set from Jerry's Gaskets. Like the OEM look better than the braided look.
[IMG]http://www.c3vr.com/member_uploads/401_500/419/thorsten_norge.gif[/IMG] [B][I]Jim O. [COLOR=white]..............[/COLOR][IMG]http://www.c3vr.com/forum/smileys/smiley27.gif[/IMG] [IMG]http://www.c3vr.com/member_uploads/401_500/419/driving1.gif[/IMG] "[COLOR=red]The Toys[/COLOR]" [/I][/B]
...'90 ZR-1.......'70 roadster.......'78 Trans Am....
[I][B][URL="http://www.c3vr.com/member_uploads/401_500/419/TheToyII_102_852.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/TheToyII_104_65.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/TheToy.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/Itsa70_36a2.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/PICT3106a.JPG"][IMG]http://www.c3vr.com/member_uploads/401_500/419/PICT3106a_sig.JPG[/IMG][/URL] [/B][/I]
(click on each to see a larger version)
[I][B][COLOR=red]Save the Wave...!!! [IMG]http://www.c3vr.com/images/smilesani/wavey.gif[/IMG][/COLOR][/B][/I]
Norsky4360 is offline   Reply With Quote
