03-19-2012 | #1 |
Major Engine Miss above 3K
After sitting for a few months my 91',(60Kmi.), Has got a serious miss in the secondary induction system.
Power key off- It runs normally. Power key on- Engine goes flat above 3K.,gug,gug,gug. There are no warning lights lit. I have a Coplon duct insert, so that's not the problem. Yes, they are the original injectors. It doesn't take a genius to deduce that the secondaries aren't working, but I'm wondering what the most common causes are for this condition. It looks like there's a plenum pull in my future. Any way to avoid that? TIA, Bob.
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
03-19-2012 | #2 |
Re: Major Engine Miss above 3K
Didn't we discuss your injectors being the likely culprit in another thread?
03-19-2012 | #3 |
Replace your injectors as previously discussed. GC
03-19-2012 | #4 |
Yeah, but I hadn't yet figured out that it was only in the secondary, and that the primary was fine.
Just thought there might be something that could be done before pulling the plenum. BTW, the vacuum is fine, it pumps up and shuts off in 2-3 seconds. any thoughts? |
03-19-2012 | #5 |
NO unless the secondary pump isn't working. Have you checked that?
03-19-2012 | #6 |
If those are 91 original injectors, there toast
03-19-2012 | #7 |
Quick current draw check to verify normal pump operation:
1) Leave the ingnition switch in the OFF position and set the VOM to the 10A setting with the RED lead PULLED OUT of the VOM (protects the meter) 2) Connect the RED lead PROBE end to the POS terminal of the battery and connect the RED lead METER end to the "A" connection on the VOM 3) Connect the black lead of the meter to the RED pump TEST POINT near the diagnostic plug on the wire harness (near the ECM). You should hear the pumps come on as soon as the connection is made to the pump TEST POINT (RED wire with the black connector - a yellow alligator clip connects the test point on the harness to the black lead of the VOM in the picture). Each pump draws between 4-5 amperes. In the photo we see both pumps are running as the current draw (both are Airtec pumps in this example) is well in excess of 8A; commiserate with current draw of two pumps. However, if the current draw is ZERO, then neither pump is running - not your situation, but if the current is only 4-5A, then one of the pumps is not running. Logically, since it is the secondaries that are having the problem, then the secondary pump fuse (under the passenger hush pannel) is suspect and you'll need refer to the FSM to check it. Once both pumps are running, fuel pressure should be about 52 psi, but verification is best done with the FP gauge taped to the windshield and checked over a few quick WOT pulls. This will verify the pumps are working under load, and the fuel filter (on the passenger side frame rail, roughly in line with the door hing line) is not impeding FP/flow. Another thing to verify is are the secondary throttle plates actually opening on demand? One thing at a time, I recon... P.
03-21-2012 | #8 |
Re: Major Engine Miss above 3K- New Injectors??
Thanks Paul. I'm not familiar with that tester, is it commonly available?
From the responses, It looks like those original injectors may be living on borrowed time. Understanding that this is a stock motor car with bolt ons, If I just go for a full replacement, I've got some questions on new injectors: -What are the basic types available? Or are they all the same? -What is likely to be the most durable type? I've had this car for 18 years, and I will probably have it for at least 18 more. -What is the best type currently available? -What is the cheapest, most reliable source? -Are most new injectors flow tested and matched? If not, who offers that service? Any info, or opinions, would be greatly appreciated.
03-21-2012 | #9 |
Bob
Call John @ FIC. www.fuelinjectorconnection.com (770) 888-1662 They sell stainless steel injectors and yes they are flow tested Good luck David |
03-21-2012 | #10 | |
There are several options, but as Dave said, Jon at FIC can provide you with what you need; a "kit" if you will that includes the proper gaskets, O rings, etc. His injectors (he says) are refirbished, and come at a very competative price. Jon's reputation for customer care after the sale is stellar, should there be a problem, according to those that have used his injectors. As for most reliable, I choose new Accel injectors, on Marc Haibeck's recommendation, and have been totally satisfied with their performance. The part number is #150821 from Summit Racing. Note: these injectors are not listed by Summit (or they weren't) for the LT5 application. And, as such, there is a plastic alignment rib on the injector that has to be ground off in order for the secondary connector to work (takes a total of about 5 minutes tops to do all 8). You'll need to order two sets of 8, coming to about $587 plus shipping for two sets of 8. You'll need gaskets. Jerry's Gaskets can fix you up with the gaskets etc you need. Just let him know you're replacing the injectors, and he'll fix ya up (with the same "kit" he provides to FIC). P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-21-2012 at 01:35 PM. |
