Old 03-01-2012   #1
kevin90zr1
Default problem with new wheels
just received my a-molds from factory reproduction 17x9 and 17x11 sent to cal chrome had them black chrome coated put on new nitto tires they look really sharp but rear wheels seem to be tucked in is there any way they can be spaced out to have that factory look
kevin90zr1 is offline   Reply With Quote
Old 03-01-2012   #2
Kevin
Kevin's Avatar
Default Re: problem with new wheels
you have the wrong offset, common on aftermarket wheels. unfortunately these are the only ones commercially available these days
Old 03-01-2012   #3
I agree with Kevin...
Typical for aftermarket wheels, they say "ZR-1" wheels and will never fit right.
If the fronts are 9' and not 9.5, they are off too.
It's worth it to look for "OEM" ZR-1 wheels for weight savings and original appearance.
I appologize and not trying to ruin your purchase, but only explain the truth about aftermarket wheels. (we should add this to solutions if it isn't already there!)
Old 03-02-2012   #4
Blue Flame Restorations
Spacers?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 03-02-2012   #5
Originally Posted by Blue Flame Restorations View Post
Spacers?
Prob the best option. It appears the OP picked up a set of GS or 50/55MM offsets vs 36MM factory. GC
Old 03-02-2012   #6
VetteVet
VetteVet's Avatar
I've got a brand new pair of 5/8" DRM hub-centric spacers. That is just about what you need. You need to space out 14mm, which is about 9/16". You could go with his 1/2" spacers, but I wouldn't. If you look closely, the 1/2" spacers aren't hub-centric. They may not allow good engagement between the center of your wheels and the raised centering region of the hub. Here is the link to DRM's product page:
http://dougrippie.com/?p=408
His price is $129.95 + $109.95 upcharge for the 5/8" + $12.00 shipping = $251.90. I'll sell these for $200.00 shipped to the lower 48.
You would also need longer wheel studs. They are here:
http://dougrippie.com/?p=839
I can provide pics, but I can assure you they are unused and look identical to the ones on his website. They are a top quality product.
Jep
Old 03-02-2012   #7
ScottZ95ZR1
ScottZ95ZR1's Avatar
As Jep mentioned, you REALLY need to install longer wheel studs if you're going to run spacers to correct your offset difference. DO NOT use spacers that thick with your stock studs. [/B][/B]
The DRM spacers he's offering are of very high quality - and this is one project in which I'd choose quality over economical pricing.
ScottZ95ZR1 is offline   Reply With Quote
Old 03-02-2012   #8
batchman
Originally Posted by VetteVet View Post
hub-centric spacers
+1 - I use the 5/8" hub-centric ones and at 1/2" I'd be too close to the brake lines. Of course I'm using a 12" wide wheel so YMMV.
I've beaten the hell out of my studs and spacers autocrossing on race rubber and constantly changing wheels, they've held up fine for three seasons. And through three sets of hubs!
Best,
- Jeff
[/I]
