01-22-2012 | #1 |
Best Rear Wheel Hub Assembly?
AutoZone Duralast - $77
Timken = $110 GM Dealer = $425 Any recomondations? I have a low speed noise and vibration on number #140. I'm going to check her out today... Cheers, RH
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
01-22-2012 | #2 |
Re: Best Rear Wheel Hub Assembly?
Ron,
Doing the same thing to #458. Bought a Timken. At one point you could find private labeled NDH bearings at AZ but I don't think so any longer. Besides, how many miles will u be putting on the car yearly? |
01-22-2012 | #3 |
01-22-2012 | #4 |
See what kind of Warranty they give you with Timken.
If Lifetime i would go with Timken and you'll never have to buy another bearing. Pete
01-22-2012 | #5 |
3 year...
01-22-2012 | #6 |
I had the same problem turned out to be bad u-joints.
1990 ZR-1 #642 |
01-23-2012 | #7 |
01-23-2012 | #8 |
If there is no play in the hub - top to bottom or front to rear - then the bearing is not the problem. Sounds like a tire with some cupping ...
01-23-2012 | #9 |
Ron if you do find you need wheel hub assembly check these guys out. I bought my rear ones from them. Nos OEM. http://www.corvetterecycling.com/category_s/432.htm
01-23-2012 | #10 | |
No such luck anymore - all sold out! Looks like they only have front hubs now. |
