Old 12-04-2011   #1
phrogs
phrogs's Avatar
Default Engine parts for sale pretty cheap! Please buy me!
Ok I'm willing to wiggle on my prices come on people get some early christmas presents!
Parts are from a 91 2 bolt main 375 hp motor.
Most are used parts New will be highlighted Shipping will be extra I will combine shipping as best as I can little stuff easy big stuff not as easy.
2 bolt only parts
  • Engine block $1000 with liners
  • camshafts I have the LH intake and exhaust and RH intake $250 each
  • Left hand (Drivers side) cylinder head with numbers matching cam cover and valves $700
  • camshaft sprocket retainers $25 each I have 4 can be bundled with camshaft sprokets.
  • Tortional dampener $120
90-95 parts
  • Rear main seal housing $100
  • Crankshaft Main bearings and Conecting rod bearings New $550
  • starter $100
  • alternator sold
  • Timing chain idler sprocket $250
  • 4 timing chain guides fixed and pivot $100 Or $375 for all 4
  • Timing chains
  • short and long for camshafts $100 for the pair
  • Crankshaft to idler sprocker chain $40
  • Camshaft sprockets with washers and pins(used bolts as well but they should be replaced) $100 each I have 4 (see above for retainers 90-92 only part)
  • Camshaft retainers $25 each I have all 8, buy all of them for $175 with thrust washers and most hardware one bolt had to be drilled out.
  • Tortional damperner bolt and washer $30
  • Tortional dampener Key $14
  • Water Pump pulley $75
I have some more but this is all from the top of my head if you see something you need let me know.
johnny
JOHNNY P
Currently own
Old 12-27-2011   #2
pantera1683
Default Re: Engine parts for sale pretty cheap! Please buy me!
Johnny,
I'm interested in these parts:
Timing chain cover
Oil pan
Oil pan baffle
Oil pump suction tube & pickup
Oil pump
Do you have the bolts for all these too?
Kris
pantera1683 is offline   Reply With Quote
