Old 11-28-2011   #1
kcl98
Default Hogan Intake Manifold for ZR1
Hogan Custom Performance Intake Manifold for LT5. Custom Hogan Intake Manifold for ZR1 Corvette – all parts necessary to bolt on to a stock or modified motor, including fuel rails, lines, and adjustable fuel pressure regulator. Replaces stock plenum and injector housings – bolts to throttle body & heads. Extends already impressive LT5 rpm range by 400-500 rpms – Power peak about 7100, depending on application. Reasonable mid-range torque tradeoff for higher horsepower above 6400 rpms – ideal for big cubic inch ZR1 stroker motors, especially with cams. Approx 15-25 hp gain for approx 20 ft-lbs mid-range torque (depending on application). Moves injectors to the outside – easy access for maintenance. Approx $4,500 invested – for sale @ $2,900 or possible trade for Siamese-style ZR1 plenum & injector housings. More pics to follow soon - this one is when manifold was on the car.
Call Kevin - 630-816-3122
kcl98 is offline   Reply With Quote
Old 11-28-2011   #2
Kevin
Kevin's Avatar
Default Re: Hogan Intake Manifold for ZR1
pics?
