Old 10-21-2011   #1
ittlfly
Default Tightening Pan Bolts
Hey Guys,
I've read that removing the "K" bracing that hides some of the pan bolts is OK. I want to be sure that removing those 2 braces (pass & driver side) will not cause a structural problem?
Also, is there a particular tightening sequence to be followed?
Thanks.
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 10-21-2011   #2
Default Re: Tightening Pan Bolts
Yep, no issues, did it to change the O2
Old 10-22-2011   #3
ittlfly
Thanks, Lee.
Old 10-23-2011   #4
VetteMed
No specific tightening sequence is needed, but you do want to get all bolts started before tightening any. It can be a little difficult to get all the holes lined up initially.
Old 10-24-2011   #5
Hammer
Hammer's Avatar
Talking Re: Tightening Pan Bolts
I'd start in the middle and go side to side towards the front and back. Should get a good seal that way.
You will need to remove the two heat shield nuts on each side and move the shields away to torque the back two on each side, they are studs holding the pan on.
Old 10-24-2011   #6
VetteMed
Duhh, I just realized you were asking about tightening sequence of the pan bolts, not the brackets. Sorry for any confusion!
