Old 10-04-2011   #1
Default My Saturday Projects
With fall and winter approaching, time to get some projects completed before putting ZR away before the snow flies. So here's what I did:
1. Oil and filter change
2. Installed my ZT-2 Wideband O2
3. Replaced shift tunnel rubber gasket. Old one was ripped and heat came
up from exhaust.
4. Removed oil pan stud to seal oil leak. I used Black RTV on the stud and
then used a Doty washer to provide an additional seal. So far the stud
is oil free. No more oil leaks. If this doesn't work, it'll be time to replace
pan gasket next year.
5. Made appt for tuning for WOT on 10.14 at Speed Inc dyno.
Old 10-04-2011   #2
Default Re: My Saturday Projects
You be impressed how #3 will keep the cup holder cooler as well
Old 10-05-2011   #3
PhillipsLT5
PhillipsLT5's Avatar
GC, I want to know how you have a cool cup holder in AZ?
xfirez51, you can come out to AZ for more projects, I still had the A/C in garage on today, Were not putting them away, just the opposite, breakin them out
Old 10-05-2011   #4
"cooler" is a realative term lol
Old 10-05-2011   #5
Huge difference. And likely contributed to the smelling of
oil altho I did have oil leaking. Now, no further oil smell at WOT.
One more project this weekend. Gotta grease up the poly bushings I installed on front shocks.
Old 10-05-2011   #6
If possible, I'll try to get by on the 14th to see your pulls.
My "to do" list includes:
Pulling the cluster and replacing the tach resistor and filter cap (as needed) to restore accuracy (reading 20% high)
Maybe replacing the heater core... ... NOT looking forward to that one.
Installing the new carpet on the door panels - to finish off that chore (new carpet...looks great!)
Marc bumped the rev limit to 7600 (in prep for Sunday's festivities!) and bumped the IAC on deceleration to see if that would cure the annoying stalling.
As expected, it was leaving a lot of raw meat on the table with the limiter set at the stock 7200. Now I'll be able to shift according to performance rather than avoidance (of hitting the limiter, which was frustrating a good bit of performance).
The occasional stalling...was reduced (by hanging the high idle a bit longer), but the stalling is not entirely cured. The IAC "fix" seems to address the symptom and not so much the root cause. (Which leads me to another project: Find out why my stupid computer will not "see" my scanner anymore and get that resolved so maybe I can see what the heck is going on on decel!)
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
