09-19-2011 | #1 |
Do your headlight buckets come up when...
you turn your light switch to parking lights?
Until recently my headlights buckets stayed down when I turned my parking lights on (and my driving lights) A couple weeks ago the headlight buckets started coming up (with the headlights off) Any idea which is correct? H
09-19-2011 | #2 |
Re: Do your headlight buckets come up when...
first click, lights down
second click, lights up
09-20-2011 | #3 |
That's what I thought. Now the question is what is causing this. If I am not mistaken there's a headlight control module mounted on the side of the radiator shroud. I'm guessing that the culprit...?
H
09-20-2011 | #4 |
Hans,
Did you ever go w HIDs? |
09-20-2011 | #5 | |
the module will be bolted on the front of the wheel housing.
09-20-2011 | #6 |
Unless the car is Canadian and has factory DRLs. However I think that is not the case here
09-20-2011 | #7 |
Wasn't aware of that
09-20-2011 | #8 |
My suspicion would be a bad headlight switch. Possible shorting across the contacts when in park lamp position, sending current to the motor circuit.
09-20-2011 | #9 |
the buckets stay up when switching from headlights on to parking lights on;
the buckets close when switching to off.
09-21-2011 | #10 |
I have HID driving lights. However, hey have been on there for almost 2 years now without a problem. I use them alot as DRL's. But no, the car is not canadian.
I have an electical manual an will run the circuits down to see if the headlight switch is a possibility also. Has anyone else had this issue? H
