Old 09-13-2011   #1
mgbrv8
Default Breather Mold Project
Hey Tom the package came in today . So it begins the first rough CAD drawing is done. Next up finishing and then a mold and material selection.
Dave
Old 09-13-2011   #2
mgbrv8
Default Re: Breather Mold Project
Concerning the two different style parts I was going to make the larger style (Pic, Breather2). Now I have a question, with the lower tube style PCV valve holder? Why is one PCV tube lower then the other(Pic, Breather2(3))? Were they originally the same height but one was trimmed?
Dave
Old 09-13-2011   #3
Aurora40
Aurora40's Avatar
They have two different PCV valves. If you notice, the height with valve installed is the same across the two.
Bob Saveland
Former owner of #2517
Old 09-13-2011   #4
mgbrv8
I figured, So I will base both my dimensions off the taller one then. Now if anyone has any design changes or suggestions now is the time to speak up cause once I start making molds it gets trickier to go backwards.
Dave
Old 09-13-2011   #5
100 percent correct GM stepped em. Why?? So the mechanic (now you lol )would know which one goes where. It does make a difference. Simple and effective
Old 09-13-2011   #6
mgbrv8
So you are suppose to have two different PCV valves? If so I will copy the one I have.
Dave
Old 09-13-2011   #7
VetteMed
Dave
Yes, the valves are different, presumably in the pressure/vacuum at which they are designed to open/close.
Andrew
Old 09-13-2011   #8
Aurora40
Aurora40's Avatar
Dave
As said, yes it is correct, no one trimmed that. I assume GM went with two valves, and two different ones at that, to get some kind of progressive crankcase evacuation. They did have some various issues relating to pressure and oiling, presumably this was part of the solution.
To be clear, what you show in your photos is what GM put on the car.
Bob Saveland
Old 09-13-2011   #9
Pete
Pete's Avatar
Dave
My suggestion is make this piece like an F also this way you can put hose clamps on the top of the PCV just like the bottom.
I cut and made mine like an F and have clamps on top & bottom of each PCV.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-14-2011   #10
mgbrv8
Pete
Like this? Now this would be harder to make, I would recommend I make the other style and individuals cut it with a razor blade to make the cut out. What is the consensus gentlemen?
Dave
