08-30-2011 | #1 |
Secondary FI Vacuum Selonoid
Hey, Jim. I talked to you at Carlisle about a replacement selonoid for the secondary fuel injector vac actuators that was discontinued, and was wondering if you could fill me in on the part number and where to get it?
08-30-2011 | #2 |
Re: Secondary FI Vacuum Selonoid
08-30-2011 | #3 |
Thanx Frank, I'll check it out.
[FONT=Arial Black]#1679 in '91[/FONT] |
08-30-2011 | #4 |
It was nice to meet you at Carlisle.
If Jerry doesn't have the original style, here is the part number for the substitute that I showed you at Carlisle: GM 1997225 This solenoid valve has a different bracket and the plug is "key'ed" with a groove, but it can be made to work. Jim
08-30-2011 | #5 | |
So as Jim says, it can be made to work.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
09-02-2011 | #6 |
Thanx for the info guys!!
