Old 08-17-2011   #1
Paul in VA
Default 91 ZR-1 Can the Speedo cluster be updated...
HI All:
Can the '91 ZR-1 cluster be exchanged with/updated with a later year cluster?
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 08-17-2011   #2
Default Re: 91 ZR-1 Can the Speedo cluster be updated...
Unknown but I would love some of the features the 92 came with in my 91 with the "guages" function. Great question.. Has anybody done this? Or would the BCM/CCM come into play here? Anyone? GC
Old 08-17-2011   #3
Will a 92 Cluster work in a 91 with all the features of the gauges function? Any clue? GC
Short: No
Long:
the 90-91 LCD uses a different data pattern from the CCM then the 92-96. you could install a 92 ccm and cluster in your 91, I did on my dash conversion when I had a 91 dash in a 89. BUT I still did not have the extra digital gauges and I had a communication error between the CCM and ECM. you could possibly run a 92 MEMCAL in your 91, but I would verify that all the pins are the same and you have a correct ECM. IF all the ECM pins are correct and you had the CCM, ECM, Cluster and MEMCAL for a 1992, it is possible that it will work.
That would be a cool thing to try, but keep in mind the CCM stores the mileage for the car as well
Old 08-17-2011   #4
Oh yeah, I think you will also need the DIC membrane from a 92-later DIC to work correctly
Old 08-17-2011   #5
Would be a neat project.
