Old 08-06-2011   #1
mgbrv8
Default Help!
I put the battery in and was going to start the car from a very long slumber and it wont ever tickle the starter the security light in blinking with the key in and out and everything else is working is this a VATS issue and what do I do to correct it?
Dave
Old 08-06-2011   #2
Kevin
Kevin's Avatar
Default Re: Help!
battery could be bad. these cars are battery hogs, they don't run right without a fully charged battery
Old 08-06-2011   #3
mgbrv8
Default Re: Help!
Nope its a fresh battery, This is torture
Old 08-06-2011   #4
mgbrv8
Default Re: Help!
The ignition was on accessory when I put the battery in I am thinking I have set off the VATS off
Old 08-06-2011   #5
Kevin
Kevin's Avatar
Default Re: Help!
you could try taking the battery out again waiting an hour or so and then trying it all over again
Old 08-06-2011   #6
mgbrv8
Default Re: Help!
My fuel pump isnt priming so I think it must be the vats
Old 08-06-2011   #7
mgbrv8
Default Re: Help!
Okay now its cranking like it had a sticky solenoid or somthing, but now the fuel pump isn't pumping. Any idea It has a full tank of gas.
Old 08-06-2011   #8
mgbrv8
Default Re: Help!
Dose a 91 Z have the Fuel pump test connector in the same place as the 90
Old 08-06-2011   #9
mgbrv8
Default Re: Help!
I think I found the connector, it is the one coming out of the main loom from the ecm right in front of the wiper motor. Now I put power to it from my test light and I didnt hear any pump sound. Do I Have bad pumps?
Dave
Old 08-06-2011   #10
Kevin
Kevin's Avatar
Default Re: Help!
unless you absolutely need the car tonight, take the battery out and let the car rest overnight. if it is a vats issue every time you turn the key you're adding time to the lock out
