Old 08-05-2011   #1
mgbrv8
Default Drain plug mod
I know you can buy these but nothing on the shelf uses neodymium magnets they are incredibly strong. I happen to have quite a few in my home machine shop drawers. I took a 1/2" one and used a 1/2" drill and machined the end of my drain plug on my lathe now if you don't have a lathe a drill press will do just fine. It went in with a nice press fit. I have put these on all of my cars drain plugs I even dangle one in the power steering reservoir on stainless wire on all my cars. And I have always been amazed how much more fine particulates they collect then regular magnets. The more I can catch before it goes through the oil pick up the better. Also I don't think it will hurt any NCRS points
just thought I would share.
Dave
Old 08-05-2011   #2
secondchance
Default Re: Drain plug mod
Dave
Unless someone saw this post and snitch on you.
Old 08-05-2011   #3
mgbrv8
Good point secondchance
Dave
Old 08-05-2011   #4
Jagdpanzer
Jagdpanzer's Avatar
Great idea and fine work!
Where do get these magnets?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-06-2011   #5
very slick Dave!
Old 08-06-2011   #6
jrd1990zr1
jrd1990zr1's Avatar
Very Nice!!!
As far as the NCRS issue, you can't see the magnet when the plug is installed so it should not have any point deduction.
On the oil pan issue, when I had my 1990 judged at a Regional meet I got hit with a point deduction because my drain plug did not have a white nylon washer, it had the metal washer with the rubber insert. I do not believe the NCRS manual is correct on this issue since the Z was a very low mileage car.
I changed it to a white nylon washer for judging at an NCRS National event and had no points deducted.
Just thought I would pass this along.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 08-07-2011   #7
gbrtng
gbrtng's Avatar
The NCRS manual is wrong - again. Never had a plastic washer ...
Old 08-07-2011   #8
mgbrv8
I get mine at radioshack the call them rare earth magnets
Dave
Old 08-07-2011   #9
You would think the NCRS snobs would have all of this hashed out BEFORE they started judging cars.No sure but it only seems right.
