Old 08-02-2011   #1
Y-me
Default Exploratory surgery plenum removal, need help with hesitation
Well Just removed the plenum really friggin' easy just lots an lots of hidden connectors and vaccum lines. Seems the car woiuld have been way less complicated had they just built it as full time power. Most the lines and actuators are dedicted to opening/closing the secondaries. Anyhoo, the car came with reciepts 500 miles before I got it for all new Compressor (looked new too), accumulater (look at the bubba engineering on the the drier strap) new orifice tube, new a/c line, flush, retrofit/charge, and 2k later there is an old chewed up clutch pulley, Really?! you spent 2k for your a/c not to work and ignored a 50 dollar part? It'll be interesting to see if it works when I get it back together.
I pulled the plenum and the coil pack looks new so does the ignition module, I know it just got a new starter and someone spent some money trying to track down this problem. I put new plugs in it. Someone else had cleaned the throttlebody, although it looked like maybe the outer T/B gasket may have had a tear down low by the IAC. It has obvious new plenum gaskets, and I'm gonna check all the vacuum lines as soon as I get a guage. Any other hints clues for the hesitation? Does it right off idle in normal and full power, will check fuel pressure and ohm the injectors, and trace the plug wires tomorrow.
Damn you Bubba! I have the proper part on there now, I'm 65% anal.
Y-me is offline   Reply With Quote
Old 08-03-2011   #2
QB93Z
QB93Z's Avatar
Default Re: Exploratory surgery plenum removal, need help with hesitation
While you have the plenum off, I would suggest taking a coil resistance reading on each injector. Normal would be 12-14 ohms. Any that are lower than the rest indicates a failed of failing injector that can lead to misfire and hesitation.
If you have some that are low, I would replace all the injectors.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 08-03-2011   #3
If your car is a 90-92. Just get new FIC stainless steel injectors and be done with it. It's just a matter of time untill they go.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 08-03-2011   #4
Y-me
All injectors ohm out fine 12.5 average. I had to remove one intake manifold cuz I dropped on injector clip down a primary hole (great) where can I find an intake gasket set?
Old 08-03-2011   #5
Kevin
Kevin's Avatar
try http://jerrysgaskets.com/ for all your lt5 gasket needs
Old 08-03-2011   #6
Right here....
http://jerrysgaskets.com/store2/root...products_id=10
Thank you Kevin!
Old 08-03-2011   #7
Kevin
Kevin's Avatar
pizzas on you next time we're at the gathering who am I kidding I just want to make the friggin thing
Old 08-03-2011   #8
Whaddya mean "on me"? I bought last time
Old 08-03-2011   #9
And it was gooooooood !
Frank Urbo.
Old 08-03-2011   #10
Try to ohm them when they are hot. That is when the bad injectors rear theyre head. They can be pinned out from the ECM.
Frank Urbo.
