Old 06-26-2011   #1
C4Fan
Default Refurbishing/Restoration Process
I would like to know the thoughts, opinions and experiences of fellow ZR-1 owner's who have had refurbishing and restoration work done to their cars. Mine is a '91 with about 53,000 miles - runs and drives fine and looks good. I love this car and plan on keeping it for a long time. My free time is very limited so I need to entrust the work to reputable shops and specialists. I'm in NE Florida.
What I'm interested to know is about work process order for restorations. What have you done with your car and in what order? For example, did you have the engine area worked on first and then the chassis and finally body/interior? I'm thinking you start with mechanical work first and then finish with body.
Thanks in advance for taking the time to share your process experience and tips working with Corvette Shops and Specialists. I appreciate the feedback. I'm new to posting on forums so please excuse me if my replies are slow or mis-directed, but I'm learning.
C4Fan is offline   Reply With Quote
Old 06-26-2011   #2
gbrtng
gbrtng's Avatar
Default Re: Refurbishing/Restoration Process
I'm in the wait 'til it breaks mode yet, but the 'ol turq's nose is getting pretty beaten up so
paint comes next ...
Old 06-26-2011   #3
mike100
Mine had 26k miles on it, but had specific deficiencies.
found a couple of missing pieces, repaired the Bose speaker amps, fixed the oil cooler line leak and just cleaned the whole engine bay with radiator removed etc. The engine doesn't leak a drop and all the electrics worked, so I just concentrated on the broken parts, old injectors, plenum porting work etc. Traded for a quieter exhaust and raised up the (previously lowered) front suspension once I figured out how to do it. I did spend about 3 weeks playing with burning a chip to be a little more emissions friendly after I examined the two chips I owned for it (we have a chip burner at work- so it was another thing I jumped into).
then the trans came out for a repair and I took the opportunity to put in all new u-joints all the way back and then to rebuild the shocks. I didn't have a plan exactly, but one thing is sure- that minimal cosmetics and no paint and body would be done until the bugs were worked out mechanically.
The car sat in storage so much, it really had some issues being driven. The bulk of the work took about 4 months after hours in my garage (except for the trans job).
If I had a plan or actually realized how much money I was going to spend, I could have jacked up the car once, thrown $5G's at it and dropped it back down, but since I did it one project at a time, I'd say I took the wheels off about 7 or 8 times.
Old 06-26-2011   #4
Kevin
Kevin's Avatar
depends on what you want to do with it. my DS seat needs a little love so I plan to do that, maybe at carlisle this year, and rear hatch weather stripping, I can't seem to keep the DS rubber from cracking. other then that maybe carpet, not sure. my car doesn't need much to it, a good detail would help quite a bit. I mean, i'm pretty good at detailing by hand but I don't trust myself with a buffer. I also would like to have the motor PCed but if i'm doing that I might as well port it too...it's really a slippery slope.
I don't really need to "restore" my car. my paint is still fine, my interior by and large is still fine. Why do you think that your car needs restored? I'm looking to "restromod" mine when the time comes. I'd like to step up to a new set of wheels right now, but I don't have the money to spend on new wheels/tires right now.
my current to do list:
fix my power key
TB coolant bypass
ds lumbar repair
IAT sensor relocation
change out rear lines/calipers to SS lines and GS calipers.
replace rear hatch weatherstripping
general clean up. it's been years since i've had the opportunity to really get dirty and clean my car the way i want. and i'm not going to have time before carlisle either as i'm moving just a few weeks before it. maybe in the spring when i pull the car out of hibernation I can get my normal detail work done to it so i'm not playing catch up all the time.
Sounds like a fun weekend
Old 06-26-2011   #5
secondchance
I got my second ZR-1, a 94, black on black with about 30,000 miles, in 2000 in Birmingham, Alabama. At the time I was living in Lake Mary, Florida.
It was in pretty decent shape except the motor just wasn't running right based on my earlier car - a 91, red/black.
Anyway I used this car as my daily driver. By the ned of 2008 I had accumulated 107,000 and the car was beginning to show wear and tear from the mileageand years. It was time to decide whether to restore or get rid of.
Hooking up with the WAZOO gang gave me enough confidence and access to a hydraulic lift, more tools then I had ever dreamed of and, above all, a team of dedicated and skilled ZR-1 guys.
First I tackled the motor. The single most important was getting rid of old injectors (all 16 of them for $360 from FIC). Ofcourse, I redid all vacuum, and coils. This made a world of difference. A lot of cleaning was in order and while at it I custom mixed high temp paint to approximate aged factory color, sprayed on with an air brush and sealed it with high temp clear. Oil pan gasket wasreplaced also.
Once the motor was tidied up, I got into drave train - mainly rear bushings, bearings and new shocks.
Now that I was pretty happy with mechanical aspect of the car, knowing all is well and working properly with no major issues, I felt comfortable enough to sink some money in cosmetics. Finally found a good, reasonable, body shop and had the car disassembled, block sanded and topped off with 2 stage paint in original color - black.
Since then I have been making minor repairs as needed and tidying up the interior. Oh, I forgot to mention weatherstrips - stay factory.
Is it over? Hell no!
Following are additional work I have on to do list:
* Headers.
* P & P intake and injector housing.
* Kenwood indash navigation.
* Coil over.
* 18" CCWs and tires.
* Big brake conversion.
* Head porting.
I am sure I forgot something and someting new may get added.
Basically as long as you are mechanically comfortable with the car actual sequence is not that critical. It seems you have a sound car so you can follow your own preference.
As for great shops near you, Burke's Corvette in Casselberry is the best body shop I have ever dealt with. Go and take a look at Tim's ZO6 and you will know what I mean.
As for the mechanicals, for your convenience, Corvette Master's is right in frontof Burke's Corvette. They are both behind Roger's Corvette.
I trust both of them with my Z anytime.
I may go down to Jacksonville this winter since my yonger son is starting his 2nd year at Florida Coastal School of Law in Jacksonville. Hopefully I will see you then.
Old 06-26-2011   #6
Z Factor
Z Factor's Avatar
Smile Re: Refurbishing/Restoration Process
Hello, and I am glad to see you finally took the plunge with your first post.
You will find that most everyone is helpful here and not the type to give you a rough time for asking questions(unlike some other forums). So feel free to ask for help/suggestions because there is a wealth of knowledge here and forum members eager to help out a fellow KOTH brother.
It is not the critic who counts; not the man who points out how the strong man stumbles, or where the doer of deeds could have done them better. The credit belongs to the man who is actually in the arena, whose face is marred by dust and sweat and blood; who strives valiantly; who errs, who comes short again and again, because there is no effort without error and shortcoming; but who does actually strive to do the deeds; who knows great enthusiasms, the great devotions; who spends himself in a worthy cause; who at the best knows in the end the triumph of high achievement, and who at the worst, if he fails, at least fails while daring greatly, so that his place shall never be with those cold and timid souls who neither know victory nor defeat.
Theodore Roosevelt - April 23, 1910
Old 06-26-2011   #7
C4Fan
Thanks everyone for your thoughtful answers. I appreciate the input and look forward to the journey. I'm not in a position to do the mechanical work myself so I'll have to seek outside shops and specialists.
All C4 ZR-1s are very special cars and I just want mine to be the best it can be. I specifically bought one with more miles on it so I wouldn't be concerned about using it and adding more miles - but not as a daily driver. I want to keep it looking stock but want everything to work reliably. In other words, I want the car really well sorted so it performs as designed.
Old 06-26-2011   #8
Blue Flame Restorations
Just don't let anyone squish it with a front end loader and your restoration will be a breeze. I'm speaking from experience.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-26-2011   #9
VetteMed
I'm not too familiar with shops in the area, since I do all of my own work, but I'm only about an hour and a half from Jacksonville if you ever want to attempt a plenum pull or other one-day type project!
Old 06-26-2011   #10
C4Fan
I've followed your progress with the '88 prototype Blue Flame and I am envious of your technical skills. Your project is coming along nicely.
Thank you for the very kind offer VetteMed. Very cool of you. I see you once had a Red/Saddle '91. Mine is a 1991 Red/Saddle VIN 1464 that I found and bought in the For Sale section of the ZR-1 Net Registry. I really like that combo. Your #302 sounds interesting - love to keep mine healthy like that up to 189,000 miles and beyond!
Tags
florida, restoration, shops, specialists, technical
