Old 05-23-2011   #1
Topfuel
Topfuel's Avatar
Smile Thinking of making some Aluminum pulleys
As the title says I am thinking of making 10 sets of aluminum billet pulleys. What I am thinking of making are: water pump , alt, If possible Power steering pulleys. Machined finish you can polish if you want then. Not sure what a set will cost or sell for but just seeing if there is any interest. Maybe the belt tentioner pulley also as an add on.
Question should I speed up or slow down the water pump pulley? If so how much % wise.
Thanks,Mike
Topfuel is offline   Reply With Quote
Old 05-23-2011   #2
Default Re: Thinking of making some Aluminum pulleys
How about an Under Drive for the ATI?
Old 05-24-2011   #3
I think you would want to slow it down due to cavitation at higher RPM, undrive I believe solves that issue
