Old 03-21-2011   #1
sammy
Default where can i find a port throttle selinoid
i am in need of a port throttle selinoid. can these still be bought new and if so where . thanx in advance for your help. would be interested in a good used one also
Old 03-21-2011   #2
Default Re: where can i find a port throttle selinoid
Brad,
Search this forum or CF. Some have found use of a different part # that works.
Old 03-21-2011   #3
If you don't find what you're looking for elsewhere.....
http://jerrysgaskets.com/store2/root...roducts_id=502
Old 03-22-2011   #4
VetteVet
VetteVet's Avatar
Sammy,
I've got a working used one that I pulled off of my 91.
I have no use for it as I have removed my secondaries.
I also have most of the other secondary parts as well. Some of my secondary shaft bearings are toast, but everything else is good.
Jep
Old 03-22-2011   #5
ScottZ95ZR1
ScottZ95ZR1's Avatar
Originally Posted by VetteVet View Post
Sammy,
Jep
I would like to buy it if Brad goes a different route, Jep.
ScottZ95ZR1 is offline   Reply With Quote
Old 03-22-2011   #6
sammy
thanx for the responses. since i have 2 cars i am going to buy the 2 that were so kindly offered to me . i want to have a spares . maybe one day i will do the secondary delete mod
Old 03-22-2011   #7
ScottZ95ZR1
Jerry's site shows 2 units in stock. So are you buying them both - or one from Jerry and one from Jep?
Old 03-22-2011   #8
Last one I bought new was from Brown Chevrolet off of Ebay. Did a quick search and dont see any listed on Ebay at the moment. Was in the $75-$100 range.
Old 03-23-2011   #9
limey
http://cgi.ebay.com/ebaymotors/NEW-A...Q5fAccessories
Giving away trade secrets here, just make sure to remove the little tab inside the electrical connector terminal so the harness can fit.
I know the mount is slightly different, but it bolts up just as is, or if you really want to be slick, remove your old mounting bracket and re-use.
limey is offline   Reply With Quote
Old 03-23-2011   #10
nice one!
