Old 03-12-2011   #1
mike100
Default LT5 idle strategy (1991)
So I have the mid 1991 production calibration 'AXFK 0277' chip in the ECM.
Car idles fine parked- I don't know the exact idle (scanner is out for repair), but it looks like 750-800 or so cold, 900 warm on the dash tach. This is fine, my problem is with the IAC scheme when the car is rolling. It would seem any VSS input at all runs a higher idle which drives me crazy as it seems more difficult to drive slow in parking lots and such. It also doesn't like to slow down in the tall gears as much as it should.
I fixed all the vac leaks...I've even blocked off the pcv pipe just to see- it's clearly the strategy of operation.
Is there another later calibration that doesn't run on so high at zero throttle position? I'm going to do a chip soon so I wanted to know if there is a better factory base code to work from.
Old 03-13-2011   #2
VetteVet
VetteVet's Avatar
Default Re: LT5 idle strategy (1991)
BFXB is the calibration that you want.
