Old 03-05-2011   #1
lakemeadzmonster
Default Full Power Light blinks on and off 1990 Model
Any ideas, my full power light blinks on and off at times it stays on other times it doesn't, I'm starting to think I my secondary fuel pump or relay, the switch feels fine but I have not pulled my console to check it.
Any ideas?
[SIGPIC][/SIGPIC]
lakemeadzmonster is offline   Reply With Quote
Old 03-05-2011   #2
todesengel
Default Re: Full Power Light blinks on and off 1990 Model
Any ideas?
sounds like that would be more an issue with the contacts in the switch. Are you losing power when it flashes?
todesengel is offline   Reply With Quote
Old 03-05-2011   #3
lakemeadzmonster
Question Re: Full Power Light blinks on and off 1990 Model
It seems to be leaning out after it blinks for awhile which might be affecting my secondary fuel pump? when the power seems does seem to be less.
[SIGPIC][/SIGPIC]
Old 03-05-2011   #4
todesengel
The other guys with more experience might have a different take on it, but I would try jumpering the wires outside the switch to see if the light stays on. I would imagine that the switch could fail, and that is where I would start.
Like I said, others may disagree, this is just mho
Old 03-05-2011   #5
Aurora40
Aurora40's Avatar
Yes, it's most likely the switch. Wiggle the key and see if it goes on and off. You may have to turn it back from all the way right to find the "sweet spot".
If that's the problem, it is a simple thing to pull it out and adjust it. The '90 switch is a very basic device, not like the '91+ one.
Bob Saveland
Former owner of #2517
Old 03-05-2011   #6
lakemeadzmonster
I just got thru going on a short ride , light stayed on and no power issues, I believe the valet switch could be the issue. Is it a 2 wire switch? to the contactor?
[SIGPIC][/SIGPIC]
Old 03-05-2011   #7
lakemeadzmonster
It does blink on and off it if I wiggle the key. Do you pull the console? Thanks everyone.
[SIGPIC][/SIGPIC]
Old 03-05-2011   #8
sammy
if you want you could just put in a toggle switch, i did that on a red 90 that i traded in on my 92 . its an easy job just be carefull when removing the upright panel that contains thr switch as there is a phillips screw in the airconditiong duct .
Old 03-05-2011   #9
lakemeadzmonster
Another test. Confirmed, Bad switch.
I would like to keep it original.
Are Valet keys, keyed alike, for those 1990 switches? My keys are like new.
Does anybody have a 1990 model valet switch,they would part with?
[SIGPIC][/SIGPIC]
Old 03-05-2011   #10
Aurora40
Aurora40's Avatar
It's easy to fix the switch. Take off the center stack, and there's a ring you knock off to remove the switch. Then take the sleeve off the switch and you'll see the contacts. It's super easy to bend the contacts back so the switch functions correctly.
Bob Saveland
