Old 03-02-2011   #1
Scrrem
Scrrem's Avatar
Default Muffler Bracket Bolts
Just got my Corsa exhaust installed and discovered that my mufflers tip are pressing up againstthe bumper cover with only a few threads started on the muffler hanger bolts. The system I installed was pre-welded, so I don't have the luxury of loosening clamps and making the adjustment. I will need to get longer bolts and a spacer to give me proper clearance. I have heard other members say that there hanger bolts are really long. Was this hanger made with different length bolts? If nothing else guess I will need to fabricate a new bracket with longer bolts.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-02-2011   #2
QB93Z
QB93Z's Avatar
Default Re: Muffler Bracket Bolts
I just measured the hanger bolts on my 1990 ZR-1 and there is 1 3/8 inch of bolt below the frame. There are about 2 threads exposed below the nut that secures the rubber block. SO, I guess I was wrong about your "U-bolts" being short.
I took some other measurements but I will need to use a camera to describe the parameters. I will post them up in a few minutes.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 03-02-2011   #3
Scrrem
Scrrem's Avatar
Yeah, I am hoping Phil chimes in because I thought he was saying that the bolts on his car were super long and he had thought about cutting them.
Rich
Ron Davis Radiator
Old 03-02-2011   #4
QB93Z
QB93Z's Avatar
I took some more measurements:
Top of tang that the muffler hangs on to the bottom of the outlet pipes is 5 - 5/8 inches. (The picture shows the measurement a little off because I couldn't get a good angle with the camera.)
Frame above front of the muffler can to the top edge of the can is 4 1/2 inches:
I hope this helps Rich. If you need more measurements, let me know.
Old 03-02-2011   #5
Jagdpanzer
Jagdpanzer's Avatar
Here are what mine look like
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-02-2011   #6
QB93Z
QB93Z's Avatar
Hey Rich, The bolts on my 1993 look like Phil's (but no where near as clean). I guess that is why I remembered long bolts.
I will be glad to trade you my long bolts for your length-defficient set if you want to try putting spacers above the rubber blocks to adjust you tip clearance.
Let me know. I can take them out Thursday and give them to David. He will be at George's on Saturday for the header install. Or, we can meet up in the future, but I have shows the next three weekends.
Old 03-02-2011   #7
Scrrem
Scrrem's Avatar
Jim, Yeah, that would save me some fabrication of new brackets. Phil is fixing me up with some spacers. If you want to give them to David, we can swap on Saturday.
Thanks Jim!
Rich
Ron Davis Radiator
Old 03-02-2011   #8
QB93Z
QB93Z's Avatar
OK Rich. I will update you when they are in the Official WAZOO Courier's possession.
Old 03-03-2011   #9
QB93Z
QB93Z's Avatar
Rich, The Exhaust Bracket Bolts have departed Westminster and are on their way to George's Garage. Have fun on Saturday, I wish I could join you guys for the header install.
Old 03-03-2011   #10
Scrrem
Scrrem's Avatar
Thanks again Jim!! So we both save some gas expense...Why don't I go the antique show in Chantilly VA and you can go to George's ?
Rich
Ron Davis Radiator
