02-02-2011 | #1 |
Compression testing
As I have tested several other engines for compression, (and forgot)
What should a good cond stock LT-5 test at please.
1995 Convertible Supercharged Auto 1974 454 550hp (avatar car) On the blocks- -Scharger install ! 1992-Zr-1 Sold. Watson Headers Ported Plenum, Housings Random tech cats Fidanza Flywheel Chipped, Relocated Mat Woods 165 stat Borlas, Straights 1996 Lt4 Sold 1994 Lt1 Sold 2004 Z06 Sold AKA** Illenema |
02-02-2011 | #2 |
Re: Compression testing
185-190+
02-02-2011 | #3 |
Wow, I would have guessed higher.
peace Hog |
02-02-2011 | #4 |
My 21K mile car is about 210-215.....I was told by one of the assembly line sups that they saw values up to 300....varied from engine to engine.
02-02-2011 | #5 |
Cool, I can see there being quite the variance esp. with the cam drive system the LT-5 employs.
peace Hog |
02-02-2011 | #6 |
September 8th, 2010:
#1 = 220 #2 = 222 #3 = 220 #4 = 220 #5 = 225 #6 = 215 #7 = 230 #8 = 221 Sept 8th, 2009 (yes, exactly the year before): #1 = 180 #2 = 195 #3 = 175 #4 = 180 #5 = 175 #6 = 178 #7 = 175 #8 = 100* Both tests were conducted the same way with the same tool and with the same battery charger keeping the battery full. What was different is in the interim I ported the heads and a valve job was done in addition to replacing an exhaust valve in #8...AND after Pete timed the cams. Because of the fresh valve job AND re-timing the cams took place, it's not possible to say just what made the difference. But, there you have two sets of data from the same motor to ponder. P.
02-05-2011 | #7 | |
1990 Bright Red ZR1 #41 ZR-1 Net Registry Founding Member #415 |
02-07-2011 | #8 | |
peace Hog |
