Old 01-18-2011   #1
Default Issues w swapping Steering Column?
Getting ready to do a motor transplant on my 92 BR/ZR. While the engine bay has the room, I'm considering swapping steering columns. The one on the BR is loose in the vertical axis. Aside from needing to swap ignition tumblers, what other components will require swap or change to make this work? Is it just a matter of matching resistors in the key? I will be keeping the original CCM with the BR. Also looking to swap air bag from BR column to Aqua car column.
Old 01-18-2011   #2
Default Re: Issues w swapping Steering Column?
instead of pulling both columns apart.. take BOTH keys to the locksmith have him cut the Aqua Key with the BR resistance, Although I would check both first, it is possible that they could both have the same resistance currently
Old 01-18-2011   #3
scholtmj
scholtmj's Avatar
The steering wheel in my car is loose too, but the local Chevy dealer said it'd be $300 in labor and no parts to tighten it up.
I'd try to fix it yourself before swapping steering columns.
Old 01-18-2011   #4
tccrab
tccrab's Avatar
Sloppy C4 Steering Column, seems to be a fairly common problem.
http://domesticmisfits.net/forums/viewtopic.php?t=124
Seems pretty straightforward.
TomC
'Crabs
Possible candidate for Dynomites "Solutions" page?
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 01-18-2011   #5
72ZR1
very easy fix takes less than 1 hour.
72ZR1 is offline   Reply With Quote
Old 01-18-2011   #6
ScottZ95ZR1
ScottZ95ZR1's Avatar
TomC
'Crabs
Great "How-To" reference link Tom - thanks for sharing that!
ScottZ95ZR1 is offline   Reply With Quote
Old 01-18-2011   #7
Tom,
Thx for the link. Very comprehensive and interesting. It looks like there are several steps that could also lead to swapping the columns instead. The other choice is to remove the column and do the rebuild on a bench. I've checked with my local Chevy dealer and they will cut a key for my old column BUT with
the resistor value of the new car.
Old 01-20-2011   #8
batchman
I have found there are two "loose wheel" issues. The first is the well known issue/fix above, mine suffers from a "down/left 1/4-inch" most easily seen when getting in and out of the car.
Had a friend do the "usual fix" only to find it did not cure my issue. He's done 100s of them and can do it blindfolded.
Bought another 91 column "with good tilt" only to find the same issue. Friend has it to try and get at the root cause on the bench.
Before finding the 91 "replacement" I found an odd year/year interchange range but forgot what it was since I had a correct year "solution". Anyone know the interchangable years?
ON EDIT - per my salvage buddy's interchange guide, 91-93 manual trans will swap, there is a difference for auto trans, guessing it has to do with shifter lock.
Thanks,
- Jeff
[/I]
Last edited by batchman; 02-08-2011 at 03:32 PM. Reason: adding tech so I can find it next time I chase this...
