Old 12-24-2010   #1
Default Aqua/Gray #474 Parts Now Available!
OK. Car is in garage and now parts are available. I'm going to ask mods to close this thread so I have final parts requests and the order as received. As an FYI, the parts availability has been posted on ZR-1 Registry and in C4 Parts F/S, and PMs as well. I have kept list of requests in chronological order. I will start new thread to begin fulfilling parts requests. I prefer checks rather than Paypal unless amount is <$100
Old 12-30-2010   #2
Default Re: Aqua/Gray #474 Parts Now Available!
All,
I just posted this on CF Parts for sale but wanted to give my buds here a heads up. Some have already requested certain parts. I can ship when I get funds.
=Jeff= and I spent most of the day pulling parts. Interior is out, rear bumper is off, front bumper fascia is off.
Halo plastic. Its gray.
DIC
Lower shift boot
Bose radio
Bose radio amps are available along with antenna
ZR-1 radio bezel
Shifter console bezel
C5 brakes with PNW adapters and abutment brackets.
D44 w batwing
Steering wheel w/o airbag
Gray sport seats
Seat track and seat track motors
Door sill panels upper and lower
2 sets of F&R Bilstein shocks (Moracca valving)
Front and rear suspension pieces D/S upr,lwr A arms
D/S steering knuckle
P/S steering knuckle
Various electrical harnesses (engine and interior)
D/S fog lamp assembly
D/S front marker lamp assembly
Rear side marker lamps Both sides
Aqua Targa roof
Blue Acrylic roof
Third brake light
Window Glass Both sides
L/R Inner door panels w switches
FX3 and P/S console switch assembly
FX3 shock actuators
3 taillight lenses
Oil cooler
Radiator shroud (stock)
BCM
ABS control
ZR-1 instrument cluster
Various gray carpeting
Electrical relays and switches
Dual Mass FW
Front filler panel
Thermostat housing
Soon to come:
LT-5 motor
ZR-1 ZF6 trans with stock shifter
LT5 Bellhousing
ZF6 Master and slave cylinder
Stock LT5 cylinder heads (port matched)
Old 12-31-2010   #3
xlr8nflorida
xlr8nflorida's Avatar
Interested in:
Bose radio
antenna
ZR-1 radio bezel
Third brake light
FX3 shock actuators
3 taillight lenses
Oil cooler
BCM
ABS control
Thermostat housing
Prices?
Old 12-31-2010   #4
todesengel
All,
That is just messed up considering I tried to buy that thing a few days ago and was informed that you were going to keep it. No worries though, Corey hooked me up.
I wish you the best of luck with your garage sale
todesengel is offline   Reply With Quote
Old 12-31-2010   #5
limey
Amps
A/C Programmer
A/C Controller
A/C Lower fire wall box
All A/C lines, MUST be complete and not bent up.
Spare tyre bag maybe?
limey is offline   Reply With Quote
Old 12-31-2010   #6
My apologies but I don't recall your request. Was your communication w me? I have a ZF6 I'll be selling. I'm sorry if I am the one that dropped the ball on this.
Old 12-31-2010   #7
Originally Posted by limey View Post
Amps
A/C Programmer
A/C Controller
Kurt,
AC lines and tyre (or is it tire) bag are available. Others are spoken for so far. $125 for both + shipping
Old 12-31-2010   #8
Default Re: #474 Parts Now Available! UPDATE w Pricing
Halo TRIM panels (Gray) $30/side
Bose AM/FM CD Cassette $165 Good working order
Bose radio amps $40 ea.
OEM Antenna $60
ZR-1 radio bezel PENDING
shifter console bezel $65
C5 brakes with PNW adapters and abutment brackets $450
D44 3.45 w batwing $1150
C Beam $80
Steering wheel w/o airbag $65
Gray sport seats (D/S bolster usual wear) $500/pr.
Seat track Good working condition $145
Seat track for parts $90
Door sill panels upper and lower $50ea.
2 sets of ZR-1 F&R Bilstein shocks (Moracca valving) $350/set
D/S steering knuckle $65
P/S steering knuckle $65
Various electrical harnesses (engine and interior) please specify for pricing
D/S fog lamp assembly $100
D/S front marker lamp assembly $30
Rear side marker lamps Both sides $50 PENDING
Aqua Targa roof VG condition $550
Blue Acrylic roof EXCELLENT condition with ZR-1 VIN $850
Third brake light $65
FX3 and P/S console switch assembly $125
1 complete FX-3 shock actuators $350
1 set FX-3 actuators with front P/S needing rebuild $225
3 taillight lenses w housings $75
Oil cooler $225
Radiator shroud (stock) $50
BCM
ABS control
ZR-1 instrument cluster $450
Electrical relays and switches please specify
Dual Mass FW PENDING
Front D/S lower wheel well panel $40
AC Control Head PENDING
AC Programmer PENDING
2 sets Stock Exhaust Manifolds w CATS VG condition $450/set
Soon to come:
LT-5 motor
LT5 Bellhousing
Old 01-01-2011   #9
gen2rt
Put me next in line for the shifter console bezel (behind xlr8nflorida) if he doesn't take it ?
Thanks,
Jack
gen2rt is offline   Reply With Quote
Old 01-01-2011   #10
Thanks,
Jack
Jack,
I have updated the list and pricing in the CF thread I posted. Haven't heard from xlr8 on this. I'll give it to this evening. He may not have recovered yet.
