Old 10-04-2010   #1
Scrrem
Scrrem's Avatar
Default R134A Conversion
Thinking about converting my 90 A/C system over to R134a. I have been told that you don't have to change the compressor, it this true? I have been reading that there is a special oil that must be used for the conversion as well. What else needs to be changed for the conversion?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 10-04-2010   #2
VetteMed
Default Re: R134A Conversion
The high/low pressure fittings are different, and all the o-rings need to be changed as well. The pressure switches need to be changed too based on the different properties of R134a. I'm no AC expert, but everyone I've spoken to about the conversion says that it will not cool as well after the conversion because the system was designed for the physical properties of R12... and given the ZR-1's already undersized compressor, that may be asking for poor performance.
Of course, someone around here has probably done the conversion and can give you better info.
Old 10-04-2010   #3
ScottZ95ZR1
ScottZ95ZR1's Avatar
I have no personal experience with the conversion as of yet but I recently purchased a R12 compressor and when I mentioned the possibility of using it in a R134A application the following was the seller's response to me.
"Although some say the Denso R12 compressors cannot be retrofitted to R134a, they are mistaken. Both the training instructors and engineers I worked with had no problem with retrofitting these compressors. Furthermore, I currently have three friends and customers C4 Corvettes that I personally retrofitted over 6 years ago, still without any problems and blowing cold air. Now what I am going to follow-up with will cause some controversy, but when completing the retrofit, use ester refrigerant oil, not PAG. The reason for this is that any chlorine still in the system can react with PAG oils over a period of time. This is also important if you ever desire to go back to R12".
ScottZ95ZR1 is offline   Reply With Quote
Old 10-04-2010   #4
unless the R12 is gone form your system, don't switch. R134a with the smaller compressor and more heat from the LT5, work against it.
now that said, my car has R134a, I think the Compressor may have issues, I have purchased a new parallel flow condenser and will purchase s compressor soon, then next spring I will charge it with R134a and see if that helps.
Another member here posted about a possible Suburban Blower motor to improve flow, but I have not heard anymore regarding it as to the correct year blower to look for
Old 10-11-2010   #5
rgfllamas
rgfllamas's Avatar
Didn't the 94's and up come with 134 from the factory? Are the compressors, condensors or evaporators different? Do the early cars cool significantly better than the late ones?
Cost of R12 has dropped in the last few years and it's pretty available, why change?
Ken
rgfllamas is offline   Reply With Quote
Old 10-11-2010   #6
Scrrem
Scrrem's Avatar
Ken
Not sure..I thought all C4's had R12.
Unless I'm mistaken, you can't buy R12 without being a licensed AC shop...right? I just wanted to be able to maintain the system myself.
This is the second post I have seen that stated R134A didn't cool as well well as R12...hum, maybe it's not worth it.
Rich
Ron Davis Radiator
Old 10-11-2010   #7
sammy
i can only speek about what i did and results . i changed all the o rings and bought the 134 fittings ,low,high. i didnt change the switches. i bought a new accumulator (big round thing up by the radiator).put in 1.8lbs of 134 and 4 extra ounces of oil . that was 3 years ago and the system seems to work fine to me . it keeps me way cool even when i went thru vegas this summer and the temp was 110
