08-11-2010 | #1 |
High RPM vibration all gears
I first noticed it in third, but am now feeling it in 1st and 2nd. Maybe I didn't notice it before or it is getting worse.
I get a strong vibration which comes on at 6500 RPM or so and keeps getting stronger the more I keep my foot in it. I am certain it is from the drive train somewhere. I feel it in the shifter mostly. Is my trans or clutch gonna puke on me soon? The car has 50,000 miles. I'm taking ideas. |
08-11-2010 | #2 |
Re: High RPM vibration all gears
When I first got my car I noticed drivetrain vibration @ RPM, and I noticed that when I really got on it I could see the shifter height modulate by close to an inch.
Turned out that the transmission mount bolts were simply loose and this is a common situation. Hope that is your case as it is a cheap fix
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
08-11-2010 | #3 |
I agree, tighten everything up, but don't overtighten.
08-11-2010 | #4 |
Hey Ryan! If your home today I can come by and check it out after work. I suspect Cbeam bolts are loose. Mine did the same thing when mine were loose except for the vibration. I would suggest getting a set of Bill B's beam plates on order.
08-11-2010 | #5 |
08-11-2010 | #6 |
+1, especially the c-beam bolts on the rear of the transmission. Overtightening will compress the tailshaft bushing & wear it out.
+1 on ZFDOC's beam plates. mmmmm good, I like 'em.
08-12-2010 | #7 |
Well Rick and I sorted most of the problem out, but maybe not the underlying cause.
I had the shifter knob incorrectly installed so we fixed that and most of the audible noise is gone. I still have a cracked plastic piece where the allen screw seats into the shifter which is making noise but not much. And, there is still a pretty strong vibration coming through the shifter at high rpm. It is doing it whether I am in gear or not. We did make a dent into this project today though. |
08-12-2010 | #8 |
"It is doing it whether I am in gear or not."
Well now that we know that the problem is being isolated .... Dual mass FW gone bad More back ground on the car please. |
08-12-2010 | #9 |
When not in gear, have you tried whether it vibrates with clutch engaged or disengaged?
08-12-2010 | #10 |
When you say the vibration occurs in gear and out of gear, was the car moving when it was out of gear?
If the car's not moving and you get a vibration with the clutch in or out then the vibration is north of the clutch disk. If the car is moving and the vibration is there clutch in or out, then it could be a U joint. TomC 'Crabs
