05-03-2010 | #1 |
WTB: Rear rim for 1994 ZR-1
I need a driver's side rear rim for a 1994 ZR-1.
Thanks, Rick L. |
05-03-2010 | #2 |
Re: WTB: Rear rim for 1994 ZR-1
Right and left rear are the same. Welcome top the forum
05-03-2010 | #3 |
05-03-2010 | #4 |
I've got one, it's not OEM, but it's the OEM-styled AFS reproduction with the deep-set lugs. Cosmetically nearly identical to OEM.
05-03-2010 | #5 |
05-04-2010 | #6 |
Singles are HTF and stock wheels in the correct 36MM offset are NLA. Most folks only want to sell as a set. Andrew has a first generation AFS copy for sale. Dont forget the original wheel where made by AFS in Japan, the only difference that you wont see is a stamped JWL on the front of the rim. Otherwise its identical. Just FYI
05-04-2010 | #7 | |
Rick L. |
05-04-2010 | #8 |
The early gen AFS's are the same. Keep in mind however the seller has one 36MM and one 50MM (GS Offset) rear to sell and not a matching pair
05-04-2010 | #9 |
05-04-2010 | #10 |
