Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 07-04-2012   #1
vilant
Default Looking to fix my A/C
Didn't realize there was regional sub-sections. Was posting on another thread about the A/C. Anyway, I have a 90' and the air will blow out cool for a little bit, then becomes warm. I assume the R 12 needs to be recharged. Does anyone know someone in PA or nearby that could do that? Or anyone that could convert to R134a? Would rather recharge the R 12, to keep everything as original as possible. Any clue on the costs of either?
Thanks, Joe
Old 07-05-2012   #2
secondchance
Default Re: Looking to fix my A/C
Hi,
You seem to be north of Philly.
I am not familiar w/ any auto service up your way. My suggestion would be call up local AC specialty auto services shops and find out if they can add R12. Also, inquire what the cost would be to go to R134a.
Old 07-05-2012   #3
QB93Z
QB93Z's Avatar
Your problem is most likely low freon, However, I have had ZR-1 cooling problems that were were not freon or compressor issues. I once had a bad relay that cycles the compressor and I once had a shorted wire to the compressor.
I recommend having a good AC repair shop do a diagnosis and then decide the best way to go.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
