Old 06-17-2020   #1
rbidwell
Default CCM for ZR1 or not?
Is there anyway of visually identifying an ECM as being for a ZR-1 or base model? I have access to an ECM with no part number or any other indentifiction on it. When I install it in the car the cooling fans start and I get a code 41 I have a stock ZR-1 prom installed. My guess is that is is a base unit.
Thanks for any help will be greatly appreciated.
If life is just a highway, then the soul is just a car. meatloaf
rbidwell is offline   Reply With Quote
Old 06-18-2020   #2
Default Re: CCM for ZR1 or not?
I believe looking inside the ECM there is a daughter board for the LT5. The LT5 ECM is also a taller case if I recall right
Watson Headers (2" Primary) - Borla Catback
Old 06-18-2020   #3
rbidwell
This one has no no daughter board. Thanks you very much.
