Old 07-25-2020   #1
32ValveGuy
Default Rear actuator stuck inside frame
Hello All,
I am looking for advice. My Z had regular Bilstein in the rear when I bought it. I bought a pair of new rear fx3 shocks. The driver side was fine I was able to get the actuator out that was tucked inside the frame. Now the pasenger rear side is another story. I cannot get it out. It gets stuck. I can feel the actuator connecter which is about 2? from the Shock tower mount. I tried to fish a wire in there to loosen it up but it doesn?t work. I think my next step is to drill 1/2 hole on the side of the frame close to the area where I hear the actuator banging the frame wall and fish in that area to see if I can loosen it up.
Your thoughts
Thanks Joel
[SIGPIC][/SIGPIC]1990 White/Red ZR-1 #1736
Bone Stock and staying that way (might cheat a little)
1959 MGA Twincam - sold
1967 Camaro SS 350 - stolen
1968 Camaro RS - traded in for a Vega - stupid
2002 Camaro SS SLP, rag top, last year haha - sold
32ValveGuy is offline   Reply With Quote
Old 07-26-2020   #2
32ValveGuy
Default Re: Rear actuator stuck inside frame
Think I?ll try my snake camera first
Old 07-26-2020   #3
32ValveGuy
Got it loose. Using the inspection snake camera I was able to locate the actuator inside the frame. I notice not to far from it was a nut that had a screw going thru it. It was one of the screws the was used for attaching the inner fender well. I removed it and fish the coat hanger wire through it and was able reach the actuator, freed it up and pulled it out of the frame. Back on the road again now with a fully functioning select ride suspension.
Old 07-26-2020   #4
ram_g
Nice! Thanks for posting.
ram_g is offline   Reply With Quote
Old 07-27-2020   #5
Just saw this And to make this a little easier with the snake camera I would have suggested the spring grabber tool used to retrieve bolts etc. GC
