09-26-2017 | #1 |
Will 355's fit?
I'm running C6 GS wheels with 325's, I found some 5th gen Viper take offs that I might get cheap (front and rear). Anyone running a 355 19 out back?
Sent from my SM-G950U using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
09-26-2017 | #2 |
Re: Will 355's fit?
Depends how they actually measure.
I'm running 345/30-ZR19 Michelin Pilot Super Sports and they are about as big a tire you will get under the rear of a ZR-1 without gutting the wheel wells.
Phil Wasinger 1994 Torch Red ZR-1 WAZOO Member George Braml Intake Last edited by Jagdpanzer; 09-26-2017 at 09:31 PM. |
09-26-2017 | #3 |
Re: Will 355's fit?
09-26-2017 | #4 |
Re: Will 355's fit?
Same here. 355s you will be rounding off a few more bolt heads.
09-26-2017 | #5 |
Re: Will 355's fit?
Maybe you can find the specs of the tires*, and look at their tread width and section width (as mounted on a specific size wheel). Once you know that, you can compare it to what you have on the car now, and see if you have clearance for the new size.
* Different manufacturers have different actual sizes. |
09-27-2017 | #6 |
Re: Will 355's fit?
1506554210562.jpg Both are 315's rears on ZR-1 oem rims. Left is Vredestein Sessanta on A-mold. Right is BF Goodrich on '90 Saladshooter.
1990 ZR-1 #1587 1990 ZR-1 #1727 |
09-27-2017 | #7 |
Re: Will 355's fit?
09-27-2017 | #8 |
Re: Will 355's fit?
They are Perelli P-Zero Corsa. 12.6" wide. Tread width on my Pilot Sport Cup 325s is 12.1".
09-27-2017 | #9 |
Re: Will 355's fit?
345/30-ZR19 Michelin Pilot Super Sports measure:
Max cross section on 12" wide rim - 13.8" , Tread width - 13", Overall diameter - 27.2"
09-27-2017 | #10 |
Re: Will 355's fit?
The info I got for the 355 was for a 12.5 wheel. I didn't see that until now.
