Old 08-02-2005   #1
A1990
A1990's Avatar
Default ZR1products.com
Just wondering how many have stepped up to the plate and bought on of these 160 degree thermostats?
Also anybody know more about the specifics on the balance pipe and air/oil separator under development?
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 08-11-2005   #2
cuisinartvette
Question
Interested in this myself. I've heard of guys making their own. How is that done, by tweaking the spring? Anyone?
Old 08-11-2005   #3
zr1mom
zr1mom's Avatar
Default
Check out: http://www.zr1netregistry.com/makethermostat.htm
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 08-11-2005   #4
cuisinartvette
Default
Thanks for the link. Will a cool thermostat affect the fans coming on/ (Haibeck chip) or do I need to change out to a different fan switch ? (PN?)
1990 ZR1, 142,000 miles-Black on black
4.09's Haibeck chip, 3"exh, K&N, meth inj.
Old 08-18-2005   #5
Nick
Default
Well, the fans will come on when the chip tells them to, and depending upon whether or not the cooler thermostat actually helps will determine if the engine heats up to the point where the chip will turn on the fans.
What did Marc Haibeck set your fan on temps at? In my Haibeck chip, both fans come on at 205 degrees F and both off at 200 degrees F.
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 08-18-2005   #6
1990 quasar blue
Default
Same here. I think that's how he sets them all up.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 08-18-2005   #7
cuisinartvette
Default
Spoke with the prior owner, he said he believed they were ste to come on at 190, off at 180?! 205/200 is believable
Old 08-19-2005   #8
Kevin
Kevin's Avatar
Default
Haibeck is 205 on 200 off
