Old 04-19-2008   #1
QB93Z
QB93Z's Avatar
Default Temperature Sensor wire length
The previous owner moved the air inlet temperature sensor from the air horn near the throttle body to the air filter housing.
There is about 18" of extra wire coiled up by the radiator.
My question is: Can I remove the excess wire or is the system "calibrated" for a certain lead length?
My guess is that the lead length is not critical but I hope someone can confirm it.
Thanks, Jim
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 04-19-2008   #2
gbrtng
gbrtng's Avatar
Default Re: Temperature Sensor wire length
The lead length is not critical as long as the wire is the same gauge or larger than stock.
Old 04-20-2008   #3
QB93Z
QB93Z's Avatar
gbrtng,
Thanks for the information. I have shortened the wires and harness and it looks much neater.
